Results 1 to 3 of 3
Thread: Why are there only two coil control pints in my ECM?
    Potential Tuner Ajax's Avatar
    Oct 2023
    9
    Hi! So, I was studying the pinout of my ECM, and it looks something like this:
    As you can see, there are two similar set of pins. One set controls ignition for coils 2 and 3 and the other for coils 1 and 4.
    I have a single coil system, so I assume those pins control the spark plugs directly by sending a signal to the coil.
    My question is, why are there two sets of pins that control the same instead of 4 pins (one for each spark plug)?
    Are two spark plugs firing at the same time? Do those pins onyl control timing, and the firing is directed by a different circuit?
    Thanks in advance for any help you can provide.
    Nov 2017
    1,524
    How about some info on what you are actually working on?
    Oct 2023
    9
    I'm not really working on anything, I'm just looking at the pinout and trying to make sense of it. It's a Chevrolet Aveo T250.
