Results 1 to 5 of 5
Thread: Adding fuel to VVE table before tuning HELP
    hey guys im trying to add fuel to my VVE table (100+ kpa) so when i go to tune it im not tuning from a car thats dangerously lean while in boost.
    i can do this on gen 3 but have never done it on gen 4. any help is greatly appreciated.
    Tuner Guy With A Chevy's Avatar
    Aug 2023
    Corpus Christi, TX
    184
    Are you referring to changing the VE table to a 2 or 3 bar chart? It can be done by right clicking the rows and and editing the row labels.
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    474
    You're tuning from a stock CTS-V VVE table. I would see where you are and tune up to WOT and then do WOT.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
    Quote Originally Posted by PGA2B View Post
    right but is there a way to say add 20 % accross the board for anything in boost +100 kpa? id rather tune from a car running rich and lean it out then start lean. ive logged for my 1st revision but the car was going LEANNN and barely at 100 kpa. just trying to keep it safe.
    Tuning Addict
    Jan 2015
    6,802
    I thought we already covered this? Once you change it to view it in 2bar just highlight then use the edit tabs to add whatever percentage you want and then calculate and work it from there. Don't be afraid to ask specific questions for clarification even if they seem stupid. We all learn in our own ways You right click on the map axis to bring up the 1,2 and 3 bar formats to choose from.
    https://forum.hptuners.com/showthrea...ve-tuning-help
    ~Greg Huggins~
