Results 1 to 15 of 15
Thread: 2006 LBZ ECM File Corrupt
    Feb 2016
    9
    Hello all, If you dont think this is appropriate for me to post here, I apologize.
    I just bought a 2006 GMC 3500, my first Duramax truck. The truck runs fine and seems to have a stock tune currently. The PO said he thinks it had a tuner on it before he got it. I bought an Edge Evolution CTS3 for the truck for monitoring and to run their tunes. When I attempt to load a tune, it tries to pull the stock file and says it is corrupted. I called Edge and they pretty much said if the can is good and communicating fine, then I probably need to have a factory configuration written in. I pulled a file with HP and it definitely seems like a stock tune. I guess my question is, can I use someone's stock tune, license it, then write it in? Or is that a dumb idea, and should I try to find someone with a tech 2 and/or dealer? Am I missing an obvious answer. I am up for any good ideas.
    Also attached is the file I pulled from the truck.
    2006 White GMC FIRST Read.hpt
    Feb 2016
    9
    No one has any insight??
    Tuner djv86's Avatar
    Aug 2023
    PNW
    74
    do you have any method of loading a new file into your truck ? what is your vin ? i can see if i have a stock file.
    07 classic
    Feb 2016
    9
    The only thing I have is HP-MPVI 1. My VIN is 1GTHK33D36F195059
    Aug 2023
    PNW
    74
    ill check later today if i have one that will work.
    07 classic
    If you want to write another file in...make sure all matches up before you do. I did it with success on my 2010 but its typically not recommended. Also double credits, since you need to license your truck vin, then license the file when you flash it in.
    2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
    2010 GMC Sierra LMM Duramax. Exhaust and tuned
    Aug 2023
    PNW
    74
    Quote Originally Posted by Dieselmanng View Post
    this morning i will have one for you . i used efilive to flash my 06 back to stock. then changed the vin to yours. then used my ford vcm2 and the gmglobal website and programming software to program the pcm to match your vin. then ill read it back out with hp tuners and place it here later this morning.
    07 classic
    Apr 2021
    36
    He will still need to license the file since they are also tied to the ECM serial number
    Aug 2023
    PNW
    74
    1GTHK33D36F195059.hpt
    there you go. that would be gm's latest and greatest file. it was read out from my 4.0.6 vcm editor
    07 classic
    Feb 2016
    9
    Good deal. I never licensed my read from my truck, so I should be good to license this file and load in in the truck, correct? The only thing I see that is different is the ECM Serial number.
    Aug 2023
    PNW
    74
    its got a different serial due to my ecm is a diff serial than yours. but i programmed my trucks vin to match yours. then used gm sps to program my ecm using the latest calibrations from gm as per your vin. then read it out with hp tuners. you should beable to load that file in with a full flash to be safe.
    07 classic
    Feb 2016
    9
    Okay. I will hopefully get to it later today. I really appreciate you taking the time to do this for me.
    Aug 2023
    PNW
    74
    youre welcome.
    07 classic
    Feb 2016
    9
    I finally got a few minutes to write it in, and it worked perfectly. Thanks again!
    Aug 2023
    PNW
    74
    awesome !! glad to hear. if you need any help with other stuff for that truck feel free to send me a pm.
    07 classic
