I'm having issues with the transmission staying in 3rd gear. I've seen that it's a limp mode which is typically caused by no power to transmission. I did verify that mine is getting power. When I'm running VCM Scanner it indicates 3rd gear no matter what I manually shift it to. Reverse does act normal, but I have no power forward. Also, no codes except for once when I reved it high to move and got a U0107.
I did add a 3200-3500 stall for the new cam that was installed. Been diagnosing myself and now stuck. Any guidance would be greatly appreciated! THANKS!
