Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: Unlocked T87A shift schedule in 8L90E help
  1. #21
    Aug 2023
    SoCal
    453
    Quote Originally Posted by voodoo tuner View Post
    i get what do you mean , but my request is different than what those Guys Are doing at the track
    Bottom Line i want to Cancel " Auto Shifting " when the gear is in L
    so i tried multiple changes on the tables and i manage to hold every Gear to the Rev Limiter without the TCM doing Auto shifting , But it Stuck in Rev Limiter and Refuse to shift up if i Tap Up
    what i did is this :
    Shift Scheduling > Full Throttle Shift RPM > Normal " rising all the RPM's to 6300 "
    Shift Scheduling > Full Throttle Shift RPM > Pattern A " rising all the RPM's to 6300 "
    Shift Scheduling > Full Throttle Shift RPM > Pattern B " rising all the RPM's to 6300 "
    Shift Scheduling > Full Throttle Shift RPM > Tap Up / Tap Down " rising all the RPM's to 6300 "
    So I called A Local Tuner and He told me to did this changes :
    Shift Scheduling > Full Throttle Shift RPM > Normal " set all the RPM's to 5800 "
    Shift Scheduling > Full Throttle Shift RPM > Pattern A " set all the RPM's to 5800 "
    Shift Scheduling > Full Throttle Shift RPM > Pattern B " set all the RPM's to 5800 "
    Shift Scheduling > Full Throttle Shift RPM > Tap Up / Tap Down " rising all the RPM's to 8k "
    and what happened ? nothing it Return to do the AUTO SHIFTING again in L
    Bummer well that's above my pay grade, hopefully someone else will be able to chime in and help with that.
    Robert Moreau
    Technical Sales and Marketing Support Specialist
    TransGo
    2621 Merced Avenue El Monte, CA 91733 USA
    Calibration | Innovation |Performance
    https://transgo.com/our-products/
  2. #22
    Quote Originally Posted by TransGo Robert View Post
    Hope someone help me about that i know it’s strange thing that the customer asked for the opposed request of what people usually want from this , but it’s customer you can’t say no to him.
