Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: rebuilt nag1
    Jan 2021
    Miami
    351
    rebuilt nag1
    greetings folks. about to taredown the ol gray nag1 to rebuild. picked up some blue tops and got a rebuild kit and another torque converter and a valve body kit. wanted to know if we could run this new build on a stock tune and just readapt until we can get a tuner for it?
    By the prickle of my thumb something wicked this way comes!2008 Chrysler 300c! 2013 heads/220/230 comp cam/LTheaders/FTI 2600 stall converter.
    Aug 2023
    SoCal
    452
    As long as it is the same unit the ratios will be the same si no problem there, no tuning needed.
    Robert Moreau
    Technical Sales and Marketing Support Specialist
    TransGo
    2621 Merced Avenue El Monte, CA 91733 USA
    Calibration | Innovation |Performance
    https://transgo.com/our-products/
    Jan 2021
    Miami
    351
    ok cool, thank you for your assistance! ill be tarring it down in a few to see if any hardparts are damaged
    Jan 2021
    Miami
    351
    Quote Originally Posted by TransGo Robert View Post
    we picked up a transgo valve body kit also.
    Aug 2023
    SoCal
    452
    Quote Originally Posted by Turbo2gnx View Post
    Robert Moreau
    TransGo
    Jan 2021
    Miami
    351
    everything is clean! clutches look beautiful, im guessing the previous owners had it rebuilt. so its looking like a bad torque converter. gonna put in the new parts tho. i tried to upload images but nothing would upload, maybe theres something going on with the site?
    Aug 2023
    SoCal
    452
    What problem are you trying to fix?
    Robert Moreau
    TransGo
    Jan 2021
    Miami
    351
    we were getting a lot of slipping to the point starting hearing noise from the tranny. metal banging and such, the car wouldnt move when i gear and let off the brakes and when you gave it gas, it would hardly move along with the banging and crunching sounds. it sounded like all gears were playing ping pong. heard a few not nice things about the converter we bought after we installed it but not sure if its the converter yet but theres nothing left to be the problem.
    Aug 2023
    SoCal
    452
    Man I can't think of anything in the converter that would make noise like you describe. The stator could be blown to pieces, sprag blown up or locked up it does not make any noise like that. Very odd that you can't see a problem in the geartrain.
    Robert Moreau
    TransGo
    Jan 2021
    Miami
    351
    so far everything is beautiful! ill be making a compressor to compress the plates to remove the snap rings and ill have all clutches out and everything exposed. im stumped as well from the symptoms and what im seeing. do you know if some of these new clutches are refurbished used fiction disks? putting the clutches ion atv fluid to soak and noticed the back of these single sided clutches have heat marks on them! i texted southern hotrod about it, hopefully ill hear back in 2 days. still cant upload imagaes, these clutches are too clean and unworn to have 190k miles on them.
    Aug 2023
    SoCal
    452
    The problem must be somewhere else, maybe the rear end? As for the clutch you are using I have never heard of them, but I have never seen refurbished frictions. The heat marks you see, it is probably just from when the lining was bonded on the steel core. As for yours looking good after 190K miles, that's normal. Wet clutches do not wear over time like a dry clutch. They only wear or burn if there is an issue causing them to slip.
    Robert Moreau
    TransGo
    Jan 2021
    Miami
    351
    well all cushion plates were flat so ill be orderingnew ones from southern hotrod. all clutches are beautiful and will be saved for another nag1, have 4 vehicles with a nag1. i want to take the torque converter to get cut open and check the condition but i dont trust the one thats in the area! i took my tripple disk with a updated stator converter from my diesel and had them check it out and was told it was all stock. the converter they gave me back let go i two days olaying with the truck. i took it to another shop and was told it was all stock no triple disk, no upgraded stator. the first shop that is local swapped my converter. 2300 for.
    Aug 2023
    SoCal
    452
    Interesting, it is the first time I ever hear of someone modifying those converter to have more frictions. The OE setup already use a clutch pack with two double sided frictions and three steels, maybe they use thinner steels. Hopefully you find someone you trust to open that converter, I would be really surprised if the problem was in there.
    Robert Moreau
    TransGo
    Jan 2021
    Miami
    351
    hopefully ill have it cut open by this weekend. so far nobody ive contacted has the dish curved cusion plates for any of the clutch packs. now we are at a standstill, cant finish the build till we get those cusion plates. hptuner isnt replying on my issue on the uploads of images! theyre customer service sucks! product decent but customer support sucks!
    Aug 2023
    SoCal
    452
    What issue are you having uploading images on other files on here? Give me some details maybe I can help.
    Robert Moreau
    TransGo
    Jan 2021
    Miami
    351
    when i got upload the files they never show up on hptuners. I've try numerus of times and no files show up for me to select. i just ordered the mercedes shift solenoids for the gears and the torque lock up, A few months of everything working ok on a stock tune we will take it to get tuned and dyno. ran into bump in the road on the rebuild, need to change all snap rings. nothing local. i didnt get a chance to contact shouthern for them yet. i think theyre open tomorrow.
    Aug 2023
    SoCal
    452
    That's odd. Let me give you a step by step view of screenshots when I do it and see where it is different for you.
    First I click on this:
    Second I click on "Choose File" and chose the file I want to upload:
    Third I click on "Upload file(s)":
    And then it looks like this:
    Robert Moreau
    TransGo
    Jan 2022
    904
    click on - go advanced > attachments > (+)add files > once it appears drag it down to where it says attachments > click done
    Jan 2021
    Miami
    351
    Quote Originally Posted by LilSick View Post
    i tried that as well. when i first got hptuners i had the same issue, contacted support and was told they would look into it.a few days later it was working. i havent been on in a long time and mow its doing the same and nothing from support.
    Jan 2021
    Miami
    351
    when i click upload, nothing uploads. the file is no longer there to download ad i have to do it againg and same.
