Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Strange DoD delete issue.
  1. #21
    Dec 2023
    12
    No I have not had time to look at it. I have studied the logs that I have made at work and I have noticed that my MAF g/s seems to be very high. I'll see if I can't get some more work don't on it this weekend. It may not be till next weekend that I get a chance to look at it. Thank you for your help.
  2. #22
    Dec 2023
    12
    Had a moment to do a quick little 5 minute log with the 02 sensor data on. I'm getting readings of 0.05 at 3,600 rpm. I'm not sure if that is the reaction of the 02s or if they are bad. I'm still learning how to read this data and what it means, however, I know I AM indeed running rich because i put a camera in to look at my valves and they are whitish. I haven't had a chance to check the pushrods but my cam is a stock grind and it is indeed in time. The engine seems to run great at high rpms not under load. In fact the CEL goes of when I stay at higher RPMs. Then it comes back after it idles for a while. I have attached the data log.
    At the 4:41 mark, then engine is warmer, you can see that the LTB1/2 and STB1/2 goes to 0 when I rev up to around 4k rpm. Once it goes back down to idle, they all go nuts into the red.
  3. #23
    Aug 2006
    5BA8
    3,253
    Quote Originally Posted by ABaker2004 View Post
    Where did you come up with that nonsense? Whitish is lean. Black is rich.
    That being said, you're dead ass lean. The O2s are bottomed out and the trims are adding a bunch of fuel. Also, more importantly, your bank 2 sensor is extremely hashy which means you almost certainly have a misfiring cylinder or 2 on that bank. That sensor should look just as smooth as the bank 1 sensor. In this screen shot you can clearly see the difference.
    EFI specialist
    email=[email protected]
  4. #24
    Dec 2023
    12
    Sorry, I meant to say lean.
    I've been told it may be a bad MAF sensor or 02 sensor. I'm not sure about that, but I know that I'm getting a code for being lean on both banks and I'll check more stuff either this weekend or next. I can't find any leaks although I have not done a smoke test.
  5. #25
    Aug 2006
    5BA8
    3,253
    You have a problem specific to the one bank. You need to make that O2 wave form look like the other bank. It's not a bad MAF sensor. You need to verify fuel pressure but even that is not the cause of the bank 2 O2 pattern. Fuel pressure needs to be verified because of the trims. Approach this like a normal diag. job.
    EFI specialist
  6. #26
    Dec 2023
    12
    Timing is set correctly, Compression is equal among all cylinders, fuel pressure is 58psi with key on, and 65 with the engine running. I was about to buy a smoke machine to check for leaks, but I may have found the issue. Not celebrating yet, but I'm going to replace this asap and see if that fixes the issue.
    Can't seem to get the image to post. Anyways its the boot of the PCV hose going into the valve cover. It's cracked all the way up. Wide open.
  7. #27
    Nov 2017
    1,464
    Fuel pressure isn’t right for a normal setup.
