For context: I am a first-time hobbyist tuner, working on tuning a cammed, 24x LS3 in my 2002 Z28 with a P01/0411 loaded with the RTT OS. I have applied the correct injector data, configured the cylinder volume, I have the MAF, DFCO, and PE disabled. I did not disable LTFT or STFT. I have reset the LTFTs since the last time I wrote the calibration. I'm now trying to work on fueling adjustments via the VE table. It's way too rich in the low RPM range.
Since I'm totally new to this, for now I'm focused on the couple cells involved at idle. Yesterday morning (30F), I went out, started a log, and let it idle up to operating temp. When it got warm enough to go closed-loop, I observed it starting to make STFT adjustments, and I can also see those migrating over to long-term as expected. Given enough time, the LTFTs settle in around -16%, with and additional negative 5-8% in the STFTs that don't seem to go away -- I'm guessing that the LTFTs are maxed out and can't get any larger? Or maybe I'm just not being patient enough -- but whatever, that's not the point of this post.
Since the trims are negative, I know the numbers in the VE table are too high. I open up the RTT interface, activate the RAM tables, and let it load in the values (which have the changes I made and wrote to the PCM earlier, so I think I'm at least doing that part right). Then highlight the two cells where idle seems to settle, plus the ten adjacent cells (to allow for interpolation), and tap the minus key a bunch of times. I've taken the target cells from ~50 down to as low as 10, but nothing changes.
My expectation is that, after several seconds, I should start to see those changes reflected in the STFTs (they should drift into the positive), but that never happens, no matter how much I change these values. I can decrease them by 80% -- nothing changes. I've waited several minutes, still nothing. The NB02 sensors continue to oscillate like normal. I've reset LTFTs while it idles; it begins trimming negative immediately and ends up right where it was before.
I've also tried applying my changes to the Primary VE table and then writing the calibration. It still doesn't seem to be making any difference.
After some googling, I learned about secondary VE tables, and figured that must be just what I need -- that I must be making changes to the wrong table since the MAF is disabled. But I can't find a secondary VE table anywhere. I know some OSes don't have one, and I'm led to believe that the 2001+ F-body OS doesn't -- so I'm guessing that's the case here.
Do I have a secondary VE table and I just can't find it? Am I coming at this all wrong? Have I failed to configure things correctly for this phase of tuning and the PCM is somehow compensating for my changes on the fly and ending up where it was before?
For clarity: the only thing I did to disable the MAF was to set the high cutoff to 200rpm. I have seen some people say that's all that is needed, and others say you need to set a dozen other things as well. Maybe that's my issue? My MAF is definitely not calibrated correctly (yet -- I intend to do VE first).
Log file: jake-robb-log.hpl
Tune file: jake-robb-tune.hpt
Scanner config: jake-robb-config.cfg
Thanks!
