Results 1 to 12 of 12
Thread: i scan and get nothing?!?
    Tuner in Training gmanz24's Avatar
    Jan 2007
    bourbonnais,IL or rogers,MN
    22
    Unhappy i scan and get nothing?!?
    i have 5 scans all using my mpvi pro, 2 are of the car off(was just trying to check ses lights), and 3 are driving around, but all 5 scans show nothing, not one bit of anything, ive got 12 minutes of nothing along with another scan of 6 minutes of nothing, am i doing something wrong? i have it configured to default imperial, was just tryin to use it for the first time.
    Dec 2006
    Edwardsville, IL
    35
    Did you select the start scan in the toolbar( shaped like the play symbol)?
    Jan 2007
    22
    im not using the comp to scan im blackbox logging and its not gettin any info at all i scan the car by holding record for 2sec, it turns on, got record light on, then when im done i hold stop it turns off, i bring it in, load it on the comp and i have minutes of nothing like i open the file and hit play it will sit there and play nothing for how ever long it was recording.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    have you considered reading the help file or watching the flash demo on how to standalone datalog?
    http://www.hptuners.com/help/getting_started_demos.htm
    Sep 2006
    Northern VA
    59
    It sounds like you need to upload a config to the interface...
    1999 C5 FRC
    Jan 2007
    22
    first, foff yes ive considered but 56k is not my friend, ive tried it before and im trying it again but the demos do not load for me, but yes i have read all the help files, offline and online. also tony first post says i have it configured to default imperial, yes i have it plugged into the car, otherwise the unit would have no power, yes the record light is on, yes i stop recording before i shut off everything, yes there is data saved, its all saved on my comp but shows nothing. i open up a log and hit play and it just flatlines the whole time for how ever long i was logging 0's across the board. i sent a file to wrench monkey last night and he goes.... thats weird.
    HP Tuners Support
    (foff667)
    28,268
    if you get on AIM i can walk you through step by step.
    HP Tuners Support
    (foff667)
    28,268
    BTW mind posting one of the .hpl logs that you did take?
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    How did you log with the car off? You mean motor off?
    Like Bill said, you need to post up information, file, ect if you want some real help.
    Sulski Performance Tuning
    HP Tuners Support
    (foff667)
    28,268
    I talked to him via IM earlier today...the only problem is he doesnt have a laptop so its hard for him to do the initial connection to properly setup the parameters. Its recording, just bad data for some reason. I gave him step by step instructions which if they work great if he follows my instructions it should go as smoothly as a hot knife through butter
    If it doesnt then theres probably something wrong with his hardware & told him to contact support.
    Jan 2007
    22
    its just like foff said like butter did some loggin today and it works great thanks again man
    HP Tuners Support
    (foff667)
    28,268
