Results 1 to 3 of 3
Thread: Can you program a replacement transmission controller with HP tuners? 2010 f250 6.4L
    I have a 2010 6.4L powerstroke f250 and need to put a replacement transmission controller and program/mate it to this f250. Is this possible with hp tuners software? Im assuming i need to write the vin to the new controller and flash it with the transmission tune. Anybody tried this before or have any advice?
    Oct 2016
    Poland
    1,743
    no, you con only load a flash part with HPT
    Jun 2023
    5
    The 08-10 TCM do not get vin written into them, the HP license sees the part numbers on both controllers and I believe the license is attached to the ECM per the vin and part number.
    If you get the same part number TCM it might work, I would just verify exact numbers on the sticker and try to write your tune to it.
