Results 1 to 6 of 6
Thread: quick question cant seem to find where i can change this
    2003 chevy 2500 has 4l80e i have shift lock enabled but why is it 1 to 2 shifts it wont hold first gear unless im WOT but it will hold any other gear is there something im missing i forgot to change thanks
    Nov 2017
    Indiana
    329
    We need a tune and log file to look at, otherwise we're just guessing.
    "I don't care how it runs as long as it chop chops at idle"
    Aug 2006
    5BA8
    3,254
    EFI specialist
    email=[email protected]
    file
    file
    Dec 2019
    MS
    567
    Quote Originally Posted by shane2500hd6.0 View Post
    Shift lock as to do with the TCC.
    [ECM] 400 - TCC Lock During Shift: When enabled, the VCM will allow the TCC to remain locked during shifts in an automatic transmission fitted vehicle.
    Look under D1 Urban. It shows to command 1-2 shift at 24mph at 50% and less.
    Over 50% it shows to command 1-2 at 256mph.
    You also have your WOT RPM Shifts at 6000rpms but your fuel rev limiter is 5700rpms
    Nov 2006
    2,745
    Check D1, D2, etc.. shift tables. Trucks have a safety shift thing where they will shift into second even if the shifter is in 1.
    Tuner at PCMofnc.com
