Results 1 to 5 of 5
Thread: Virtual Torque
    Advanced Tuner laser_racer's Avatar
    Jul 2009
    league city tx
    461
    Virtual Torque
    I know this topic has been brought up a lot and I'm just trying to make sure I'm on the right track to find the correct information to log to get those tables in alignment. The numbers I'm seeing seem a lot higher then what's in the table and higher then what's on the LT4 tables. Also noticed I'm maxing out the Volumetric Efficiency and Cylinder Airmass his max on timing table. The car is 2017 Camaro SS manual with procharger, 3 bar map sensor, and map breakout harness from the maf.
    Tuning Addict
    Jan 2015
    6,832
    I guess I don't follow.
    How are you maxing out your VE tables? They appear stock??? Didn't actually compare but they have the stock shape on the open table. You are changing it so you can look at it for boost aren't you? Set up the dynamic settings for the zones so it'll actually work in boost and can be tuned for it? Use a ZL1 for reference when setting the boundaries.
    As for spark. Change the airmass value for peak to 180 then interpolate down to 88ish. This way you keep your adjustability for lower loads and then are able to change with higher loads. Not a bad idea to run forged pistons if you're doing everything yourself or keep the timing pretty low...
    ~Greg Huggins~
    Jul 2009
    league city tx
    461
    I really didn't realize you could extend the boundaries of some tables. In the gm platform I'm use to dealing with you couldn't do that end up having to change injector settings to decrease the cylinder airmass to get it back in range.
    Quote Originally Posted by laser_racer View Post
    You can select 1-3bar scaling in the VVE editor. then the spark tables axis need rescaled to go up to 2.0.
    Jul 2009
    league city tx
    461
    Thank you both for the info
