Results 1 to 2 of 2
Thread: UI bug in E92 ECU - engine and trans max torque tables appear in wrong column
    Jul 2023
    14
    Exclamation UI bug in E92 ECU - engine and trans max torque tables appear in wrong column
    In the VCM Editor 5.1.2023, on an E92 ECU, It appears as though two menus are placed under the wrong headings.
    Under Engine->Torque Management->General->Maximum Torque
    The table ECM 12820 is shown. Its description is "[ECM] 12820 - Max Engine Torque vs. RPM vs. Gear: Maximum allowed engine torque vs. RPM and current gear for transmission protection. In some vehicles gear axis 0=P/N, 7=Rev." It would appear this is the transmission torque max table.
    Under Engine->Torque Management->General->Transmission Torque Mng->Max Torque.
    The table ECM 32920 is shown. Its description is "[ECM] 32920 - Peak Engine Torque: This is the peak indicated engine torque." It would appear this is the Engine Torque Max table.
    It would appear these two menus are flip-flopped, and from the UI it is very confusing what we are doing.
    Can someone please clarify and if incorrect please make this change in a future update?
    thanks!!!
    May 2003
    South FL
    1,375
    These tables both apply to the Engine. They are correctly labeled. The Peak Torque Table is not the Maximum Torque PID output in VCM scanner. The TCM has its own Torque Limit Tables.
    [email protected]
    Owner/GM Calibrator
