Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 79
Thread: Incorrect MPG (too high) displayed on DIC after SD re-tune
  1. #41
    Mar 2022
    Indiana
    2,939
    How come no wideband in the log? Don't have one installed?
  2. #42
    Tuner mastersorbet's Avatar
    Aug 2014
    South Carolina
    50
    I do not have a wideband installed to log into hp tuners...just a wideband gauge
    here's the log. Ran better than your last one but still kinda rough test 3.hpl
    2004 z06 BTR stg. 1 blower cam with ECS 1500 kit and 3.6" pulley, forged rods and pistons...it does ok!
  3. #43
    Mar 2022
    Indiana
    2,939
    Looks like it was hitting the lower limit of the injector min pulse. I've adjusted for that. VE adjusted also. If it's too low then it'll come back up on the next.
    You really need to have the wideband logging for higher loads later on. What wideband/gauge are you using?
  4. #44
    Aug 2014
    South Carolina
    50
    Thanks for the help...I mean it. I currently do not have a wideband logging and I'll have to take a look if the one i have can be set for logging with my MPVI1. The gauge i have is the one on the link below. I will wait till i have a way to log WB before i send another log. I don't want it to turn into a guessing game, nor waste someone's time.
    https://prosportgauges.com/products/...080f2e62&_ss=r
  5. #45
    Mar 2022
    Indiana
    2,939
    There's plenty to be done without the wideband. Another log would be useful.
    If you click on the Installation Instructions in the link it'll show you the pinout. Analog out Brown and Black can be wired to the EGR position. The logged EGR voltage can then be converted to an AFR value.
  6. #46
    Aug 2014
    South Carolina
    50
    I see what you mean. I'll order a EIO Plug so i can connect the analog signal as such. I'll post another log tomorrow with the tune you wrote.
  7. #47
    7,643
    No, the pins in the PCM that would have been used for EGR Position on the vehicles that were built with EGR (if yours wasn't). You can then log the PID for EGR Position and get a raw voltage, then set up some math that will convert that voltage into EQ Ratio numbers.
  8. #48
    Aug 2014
    South Carolina
    50
    That's the plan using the analog signal and the table in the instructions manual. Thanks!!!
  9. #49
    Mar 2022
    Indiana
    2,939
    Lambda:
    ([2811.10]/(5/0.673))+0.683
    AFR:
    ([2811.10]/(5/10))+10
  10. #50
    Aug 2006
    5BA8
    3,253
    Y'all know that car never came with an EGR right? I'm sure it can be wired up but it's not there to begin with.
    EFI specialist
    email=[email protected]
  11. #51
    7,643
    Has the trick of flipping the EGR master switch to 'Enabled' stopped working or something? Why spend the money for pro features (sorry, HP Tuners) just to get an analog input when there's one being unused sitting right there doing nothing?
  12. #52
    Aug 2006
    5BA8
    3,253
    My comment was strictly about the wiring not being there.
    EFI specialist
  13. #53
    Aug 2014
    South Carolina
    50
    Here is the log you asked for. Car felt better from the last tune, but some small things like start idle and idle down felt off. Great job though on remote tuning! test 4.hpl
    Will def need wb logging for higher level of presicion.
  14. #54
    Mar 2022
    Indiana
    2,939
    Alright. What about it felt off? Was it stumbling or just not as choppy? If it's chop that's because I messed with corrections last tune.
  15. #55
    Aug 2014
    South Carolina
    50
    While coasting down in neutral had some iddle hunting symptoms. It sometimes idled high (1200) and sometimes low (600). Besides that, not bad. Chop was there.
    Afr was pretty good...idled at 14.4 to 14.9 and cruised at the same afr. I really wish i could provide you with wb data.
  16. #56
    Mar 2022
    Indiana
    2,939
    I see. Run this instead. Add dynamic airflow to the logs.
  17. #57
    Aug 2014
    South Carolina
    50
    Here you go. It idle a lot better and it runs really smooth. The idle speed dips a bit when coasting but not too much.test 6.hpl
    I am pretty impressed. I can only immagine what you can do if i were providing you with some WB data.
  18. #58
    Mar 2022
    Indiana
    2,939
    Not going to get too carried away with idle until VE is good.
    I'd like to try something. There's another set of Deka 60 data that's been updated. By updated that means a different person doing flowbench data. Both sets are from FIC. Currently, there's inconsistency at low injector PW. Look at what STFT is doing at the cursor vs the tabulated STFT value.
    Also, adjusted O2 for airflow modes to increase drive.
  19. #59
    Aug 2014
    South Carolina
    50
    Interesting....but i thought that the average would be just that. Regardeless, i will run this tune on saturday and send you a log. Once again thanks for the help. I am actually learning as well.
  20. #60
    Mar 2022
    Indiana
    2,939
    Right. It's the distribution to make the average that's the problem. STFT at the cursor should be close to the average if it was consistent at that MAP/RPM point.
