Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: 2008 Pontiac g8
    Jan 2024
    Colorado
    9
    2008 Pontiac g8
    Hello all. I have a 2008 Pontiac G8 GT currently in the shop here and am not familiar with tuning. We are swapping the 6.0 that is knocking to a LS3 376/525 crate motor from GM. I just need to know if the ECM will work (PN 12619077) and what I need to do after I get the engine in. I am planning on buying the mpvi3 but not sure where to go from there. I downloaded the software but is there files i can use to flash the ECM?
    Advanced Tuner Josue Galban's Avatar
    Jan 2023
    Venezuela
    205
    Quote Originally Posted by Jtballinger18 View Post
    If you bro, you will be able to read, write, modify etc
    tuning and high performance
    my contacts is
    email [email protected]
    whatsapp +58 4149648393
    instagram quickxstep
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    519
    I think you will find that you are better off using the original OEM ECM from your G8 (most likely an E38). The 525 HP GMPP E67 ECM has a known issue where the idle RPM is fixed and you cannot adjust any of the idle parameters. I suppose this is fine if you want a 950 RPM idle though. If you do use the factory ECM, you will of course need to update the tune on the original ECM though...
    So do you want to just use the tune supplied from GM for the 525 motor, or do you want to actually learn to tune and improve upon the supplied calibration?
    If you are new to tuning and want to improve upon GM's tune, then this is no small feat. You will be best to employ the services of a competent tuner, and then learn how to tune.
    FYI you can re-flash the GMPP ECM with an OEM OS to allow you to change the idle parameters, but this is going to require a Tech2 and SPSMon to do that, which is going to add additional expense. So again, I say your best option is to use the existing ECM and tune it. You can also sell the GMPP ECM to put some money back in your pocket.
    A standard approach will give you standard results.
    My Tuning Software:
    VVE Assistant [update for v1.5]
    MAF Assistant
    EOIT Assistant
    Nov 2017
    1,466
    Quote Originally Posted by Cringer View Post
    I don't think he is talking about having the "Connect & Cruise" (or whatever GM calls it) package. I think this sounds just like installing a cammed ls3 in place of his original motor using his original ECM. But maybe not.
    Jan 2024
    Colorado
    9
    There was no tune supplied with the engine. I only got the engine from GM the PN is 19434642. So all i need to do is flash the existing ECM with the MPVI3 for the specs of the new engine correct?
    Aug 2006
    5BA8
    3,253
    There's several people here who can help you out. Some of us do it for a living. I sell HPtuners along with tuning service. Let me know if you're looking for professional help.
    EFI specialist
    email=[email protected]
    Jan 2024
    Colorado
    9
    That would be amazing man. This is going to be this guys daily driver and just want to make sure everything is perfect on it
    Nov 2017
    1,466
    Not going to be quite that simple. These aren't a self learning systems like the aftermarket stuff. You don't have a major change, but will still actually need to be "tuned".
    Jan 2024
    Colorado
    9
    Our shop does have the Tech 2 as well as the SPS but am not sure if swapping the engine from the 6.0 to the ls3 id be able to program the needed parameters into the existing ECM. IS that true or no?
    Jan 2024
    Colorado
    9
    I know the 2009 g8 comes stock with the ls3 but this is an 08 so im just new to programming and im trying to figure out if its as simple as loading a tune from the 09 to the 08. Sorry if thats a dumb question.
    Aug 2021
    519
    You will need:
    VCM Suite software (free)
    MVPI ($)
    Two universal GM credits ($)
    Hire a professional tuner ($)
    The Tech2 and SPSMon was if you wanted to reflash a different OS onto the GMPP ECM. I read too much into your original post, so disregard all that. Your existing ECM is just fine.
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    Nov 2017
    1,466
    You don't have the GMPP ECM to have that option if all you got was the motor. If this is a one time only deal, just have a pro tune your existing ECM.
    Nov 2017
    1,466
    I don't know if the '09 file and 08 ecm is compatible, but will still likely need tuning for the different cam.
    Jan 2024
    Colorado
    9
    I'd definitely like it not to be a one time thing as i have plans to v8 swap my Bonneville as well so i would definitely like to learn how to tune the parameters correctly. But again this is all new to me and my shop so im trying to get all of the info i possibly can about it
    Nov 2017
    1,466
    Learning to really tune will be a major time investment.
    Jan 2024
    Colorado
    9
    Not something I have with this swap but will for my future plans. Is that something you can help me with so i can get this car running good after I get the engine in?
    Nov 2017
    1,466
    No, I'm just on here learning myself. I would reach out to edcmat-l1.
    Jan 2024
    Colorado
    9
    Thank you for the help man. I appreciate it.
    Jan 2024
    11
    just as a wild thought, see if you can get a copy of the 2010 COMMODORE stock tune, they run a 6.0 L77 or L98 , SFA difference between internals apart from DOD.
    Nov 2006
    2,742
    Stay with the stock tune and just edit away. This isn't a hard setup at all to get right.
    Tuner at PCMofnc.com
