Results 1 to 10 of 10
Thread: 5.3 knocking at 23 degrees?
    Oct 2023
    39
    why am i getting knock at 23 degrees
    112+5
    222/232 CAM
    Aug 2009
    Calibrating
    3,376
    Octane and is fuel correct?
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    13,578
    Your airflow model is way off if your fuel trims are at +25% all the time in that log. Also your running too much fuel at WOT per the commanded AFR and what that wideband is showing.
    Plus you are way out of injector at that commanded AFR value, it's way over 100%. You need to fix the MAF and VE to bring the fuel trims back in line and you should start commanding and AFR around 12.2 to see what it does for the injector duty cycle and knock.
    Nov 2017
    1,528
    Is there a prize for starting multiple threads I'm unaware of? These things go more smoothly if people just continue their existing threads so they can be built on.
    Oct 2023
    39
    im using a Speed Density tune
    13,578
    Cool, well then fix the VE.
    Nov 2006
    2,801
    The fueling is a mess on this.. Everyone has already saw it.
    I don't see a problem with knock.. At the end it did the MAX retard thing like it has a knock sensor code pending.
    Tuner at PCMofnc.com
    Mar 2022
    Indiana
    2,974
    Fuel pressure problem.
    Actually. Is that even the right injector data?
    Oct 2023
    39
    33 lb inj from 06 denali
    vaccum ref
    fuel pressure stays at 55-60psi
    Oct 2023
    39
    this is where i got my data from
