Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 115
Thread: Cold start issuss
  1. #61
    Jan 2024
    indiana
    60
    You're asking for advice and pretty much refusing the post a new, current data log?
    When did I refuse anything, I ask for advice I posted the log 7 months ago and still have the same issue with 0 changes, nothing was ever resolved, if it makes you happy when I get home from my job and after I take care of my kid all night I will find time to post you a updated identical log
  2. #62
    Aug 2006
    5BA8
    5,491
    Quote Originally Posted by TYLERJ98 View Post
    Don't do it for my sake. I'm not the one who needs help.
    EFI specialist
    email=[email protected]
  3. #63
    Banned
    Mar 2022
    Indiana
    4,289
    Thing is the bank-bank imbalance wasn't always there. Back at post #36 things look much better.
    https://forum.hptuners.com/showthrea...l=1#post764017
    Something changed. Other than a new set of injectors idk what it could be.
    Load the tune from that post. Clear LTFT's then upload a new log.
  4. #64
    Jan 2024
    indiana
    60
    That was when things changed which was log 4
    I was driving around the block and then I noticed from that day it had that imbalance but nothing to this day I can find, things I have done since log 4: it has new spark plugs, new wires, injectors were warrantied, smoke tested for vacuum, new o2 sensors, tested all coils. At this point im confused as physically I cannot find anything, but the pcm is saying that there is an imbalance. Even when you hit throttle or idle it doesn?t sound at all like there is a issue or misfire or anything
  5. #65
    Jan 2024
    indiana
    60
    I will upload tonight
  6. #66
    Aug 2006
    5BA8
    5,491
    What is the combo?
    Intake manifold
    Camshaft
    Headers, design, name brand
    exhaust system behind them
    etc....
    EFI specialist
  7. #67
    Jan 2024
    indiana
    60
    What is the combo?
    Intake manifold
    Camshaft
    etc....
    JEGS sheet metal ls1 intake, Btr stage 3 v2 truck cam
    Schoenfield 1302 ls1 swap headers, then it has stainless 2.5 inch exhaust no cats to dual spintech 6000 mufflers, it has snakeeater deka 80s in it, flat top pistons, bored .03 inch over, completely rebuilt fully machined engine, I have only put 3000 miles on it before having this happen
  8. #68
    Aug 2006
    5BA8
    5,491
    I wouldn't worry about split trims to be honest with you. Not with that intake manifold.
    EFI specialist
  9. #69
    Jan 2024
    indiana
    60
    But there are points where it can reach -18% while the
    Other is like -5% that?s where my concern grew. I mean like I said tho as far as drivability it drives totally fine and sounds fine, just the data log is telling me its off.
  10. #70
    Jan 2024
    indiana
    60
    If that?s normal with the sheet metal intakes then I?ll just clean the fueling up a little more and drive it around and see what it does, I just don?t want to do any damage
  11. #71
    Banned
    Mar 2022
    Indiana
    4,289
    Like I said before it was fine now it's not. You didn't swap intakes did you?
  12. #72
    Jan 2024
    indiana
    60
    No nothing has been changed on this build at all, just randomly happened
  13. #73
    Aug 2006
    5BA8
    5,491
    Those intakes are terrible.
    As long as the trims come back closer together with some RPM let it roll.
    Post a good long log with plenty of idle and part throttle driving.
    EFI specialist
  14. #74
    Aug 2006
    5BA8
    5,491
    Yeah that you would think would indicate something happened, changed, but in general I wouldn't worry about split trims with that type of intake manifold.
    EFI specialist
  15. #75
    Advanced Tuner abc's Avatar
    Jan 2024
    958
    Have you smoke tested the exhaust?
    Checked header tube temp.?
    Inspected plugs for one not running close in color and temp. to the others?
    Run a leak down test?
    Compression test?
    Inspected valve train?
    Swap banks with the NBO2s' (and then the wiring if it will reach?) and see if it follows the O2s' or stays with the same bank.
    Seems more mechanical than digital if one day it was fine, the config. file not changed and the next day it's off by 15 percent.
  16. #76
    Banned
    Mar 2022
    Indiana
    4,289
    You did make adjustments to the FPR. The reg is downstream of the rails right?
  17. #77
    Jan 2024
    indiana
    60
    No I didn?t change it I just asked you make sure I was correct on it but it?s been 58psi from the beginning
  18. #78
    Jan 2024
    indiana
    60
    Quote Originally Posted by abc View Post
    Compression test?
    All plugs look same, I?ve swapped bank 1 for bank 2 on o2 and coils same thing, new O2s, smoked the intake for vacuum leaks, no exhaust leaks for sure before the O2s, so I guess from your list my next steps would be pop off valve covers check the rockers for any movement, and a compression test, however I?m going to drive it tonight and log it for everyone to see the updated log of what it is doing currently before I dig any deeper
  19. #79
    Jan 2024
    958
    I'm mostly in agreement with Ed, as long as I don't feel it, I probably wouldn't stress about it too much. I would do my due diligence as far as the health check/physical and be thorough with it in stages or all at once but, if no problem found, chalk it up to "it is what it is"!
  20. #80
    Aug 2006
    5BA8
    5,491
    When I asked him what the setup was, and specifically asked about the intake, I could have guessed it had one of them shitty aluminum intakes with the little bitty runners.
    EFI specialist
