Thread: 2004 GTO 4l60e ISS
    Tuner in Training MaroonMonsterLS1's Avatar
    Jul 2017
    Iowa
    44
    2004 GTO 4l60e ISS
    Curious if anyone has added input shaft speed sensor setup to a p59 in a 2004 GTO
    Or really any p59 with 4l60e
    4l80e in trucks uses pins 22/23 green for ISS
    Those pins are empty on 60e vehicles
    Curious if I can just pin them then look for the PID in the scanner? Has anyone tried this and had success?
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    329
    You would need a transmission that has the sensor already, like a 4L70E. You would need the pump, input shaft with reluctor teeth and the internal wiring harness to convert a 4L60E to have the ISS. Then I'm not sure if the P59 would read it. I'm attaching an XDF that could be used with User Defined Parameters. I think you would have to change the first two parameters to the ISS being fitted and then turn on P0716 and P0717 in the remaining 4 tables. I'm not even sure if this would even work, or if something else would need to be turned on. Of the logic could be completely missing for this to happen on a P59 with a 4L60E.
    Aug 2023
    SoCal
    452
    I don't know about the programing side, but transmission wise you would need a different stator support, input shaft, and internal wiring harness. Then externally you would need to provide a sensor ground, power and add a wire to bring the signal to the controller to the pin it needs to go to. Why would you want to do that anyway?
    Robert Moreau
    TransGo
    Jul 2017
    Iowa
    44
    Sorry I left this thread idle
    Had to do a password reset and get into my locked gmail. what a mess.
    anyway
    The trans side is No problem.
    I run a transmission shop and have all the proper transmission stuff. Wiring is non-issue.
    I was just curious if the programming/data logging side of things would work.
    I really only want to be able to log ISS
    I don't want it to play into shift tables and lockup function like it does on later t42 tcm's paired with e67 ecm in the tbss platform
    I strictly want it as a fun logging tool
