Results 1 to 7 of 7
Thread: is my tune at peak performance? can someone take a look let me know your thoughts
    Sep 2023
    8
    its 2000 corvette i feel its burning rich and when i let off wot it backfires but it runs pretty good feels stock bosch ls6 injectors texas speed cam headers no cat t3/t4 turbo map 2/3 bar 799 heads CAM I222 E226 I.324 E.324 I.550 E.5520 L111 Icl108 fuel 93 57 compressor wheel trim mapped for low & high boost setups
    Oil fitting gaskets & mounting studs included
    Capable of producing over 450 horsepower
    Wet float bearings & properly balanced
    3" inlet diameter with a 2" outlet
    .50 A/R compressor housing
    .63 A/R turbine housing
    1/8 NPT oil inlet
    T3/T4 hybrid
    Dec 2019
    MS
    567
    This is a vague question to be asking..
    What size cam?
    What Engine?
    What turbo charger specifically? T3/T4 is the bolt pattern for the turbing housing so you could go from a 45mm to a 98mm. Or are you just using whatever a 2/3 bar map is?
    What fuel are you using?
    Dec 2019
    MS
    567
    post the tune..
    Im wondering how the engine is still together with 37* timing at WOT at 6400rpms.
    Looks like your running Open Loop as well. Oxygen sensors arent reporting anything like they are disconnected.
    Im sure injectors are scaled wrong too. .33G/S airmass at 6200rpms..
    Sep 2023
    8
    sorry wrong file
    just switched it
    Sep 2023
    8
    hybrid 500hp
    Mar 2022
    Indiana
    2,954
    You said LS6 injectors, but the data is for something else.
    Aug 2006
    5BA8
    3,254
    You ain't makin "peak performance" with LS6 injectors I can tell you that.
    EFI specialist
    email=[email protected]
