Results 1 to 3 of 3
Thread: Old Jaguar.com
    Jan 2024
    1
    Old Jaguar.com
    Anybody ever dealt with this company? Is he legitimate?
    I reached out for TCM Programming and he let me know that he had done a ?background check on me and that I should understand. He referenced a couple of my posts on the HPAcademy Forums where I?m learning how to perform reflash tuning.
    He took the time to explain that there are secret torque limiters in the PCM that need to be removed. Viezu and others don?t know about them.
    He said that for two reasons he won?t provide me any assistance with the PCM ?
    1.He doesn?t want to be ?on the hook? for damages.
    2. It?s his secret.
    Just as weird, he continued by offering to put me in contact with a guy in San Diego to perform the TCM programming anyway for $650.
    What is going here?
    On Sun, Jan 14, 2024 at 7:58 PM Cameron Knight <[email protected]> wrote:
    Hello Anthony,
    I hope you understand that we are doing some background checks on people who get in touch with these kinds of requests, so I have seen your posts on hpacademy.com about what you're doing with your XFR. Quite a project to tackle
    We're quite familiar with the tunes for 5.0SC Denso from Viezu (and others who sing from the same songbook), we had to fix quite a few of them for owners who weren't getting full throttle, primarily because they miss two torque limiters in the factory tune which are not identified in the various Damos' doing the rounds, and also missed by ECM Titanium.
    Basically at ~700Nm the engine gets throttled back. Contrary to what people say on internet forums this is not because of a torque limiter in the TCM, it's these two limiters in the TCM. The torque limit programmed in the 6HP28 TCM is actually 850Nm. You won't hit that unless those two limiters in the PCM are addressed, and I don't think you'll find them with the tools you have.
    Now the bad news, I'm sorry but we can't help you with the PCM side of things, for two reasons.
    #1 this tune you are making to run on E85, being experimental, is quite risky and we don't want to be on the hook if or when something goes bang.
    #2 as you're already dissecting tunes from other companies, frankly we are not going to give away any secrets. Sorry about that.
    Now if you are still interested in a TCM tune, knowing that the raised torque limiters in the TCM aren't going to solve that 700Nm problem, well we have a contact in San Diego who can flash it for you (and no it's not that jerk Alex). But there are some other things about trans tunes that we should clarify;
    - if you put offsets or other means of falsifying the torque calculations in the PCM tune, this can have some real negative effects on a TCM tune, could be the TCM commands the PCM to throttle back even more, in the worst case the transmission could be damaged e.g. the TCM is shifting based on reported 500Nm torque but in reality it's 775Nm, things could break or wear very fast.
    - if you change rear tyre size away from stock 285/30R20, this affects the shift points, we need to adjust for the actual tyre size
    We would only be able to offer you a TCM tune through our contact in San Diego, flashing it with his equipment. It's not possible with a Kess or your JLR-VCI.
    Our RRP on the TCM tune is $650 USD and I believe there is 8.25% California sales tax on top of that.
    If you're still interested I can put you in touch with our guy.
    Regards,
    Cameron
    +61 488 121 890
    [email protected]
    www.facebook.com/oldjaguarau
    www.instagram.com/cambo_oldjaguar
    www.oldjaguar.com
    Feb 2024
    1
    I also want to find out more information about this company. Anyway, I think you should give it a try working in a new environment monopoly go
    Mar 2024
    2
    Hello sir check this company tyre Priority Tire which is offers high quality tyre
    Priority Tire voucher code available at Ritecoupons follw the link
