Hi all, first post here. I couldn't find any first post guidelines so I hope I'm doing this right... Hoping to get some input from y'all who are much smarter than me!
I just finished rebuilding my 6L80 after a converter failure tore up my old pump at ~130k. I used a CDT level 2 rebuild kit, CTS-V 6L90 TC, zip kit, new pump cover and bell housing, etc. After rebuilding I reset adapts and tuned using Bluecat Trans tool and disabled TCC apply in 1-3. I also added 10% to the TCC apply ramp. It's shifting alright so far but it doesn't look like the TCC is locking.
I took it for a test drive and was monitoring my TCC slip rpm and TCC line pressure. I could see TCC line pressure increase but it didn't seem to have an effect on TCC slip. Here's a screenshot of what I was seeing:
At the end of my test drive as I was driving up the hill to my house the check engine light came on. I read it with VCM Scanner and it was "P0741 Torque Converter Clutch Solenoid Circuit Performance/Stuck Off." I cleared it and went on another test drive to see if it would come back on but it hasn't (yet). I didn't have this issue before hand, so I'm not sure why it's happening now.
I checked line pressure at idle in park and read 90 PSI, so my initial feeling is that the pump is producing enough pressure but the TCC solenoid is bad. My understanding is that the TCC line pressure reading in VCM Scanner isn't a reading of the actual line pressure, it's the expected line pressure based on the duty cycle of the TCC apply. Is that accurate or a load of crap?
I'm afraid to drive it because if the TCC is slipping, I'm going to tear up my pump and I'll be right back at square 1. But if it's a bad solenoid it won't apply at all, so no harm no foul. In either case, could I just disable TCC apply across the board and safely drive it around without lockup? I don't want to ignore this issue so I need to get to the bottom of this, but I'm wondering if there's anything I can do in the short term to allow me to drive around without damaging anything.
What steps should I take to diagnose no TCC apply? Has anyone run into this issue or know what's up?
Edits:
2024-01-15: I added the log file I took the screenshot from. I couldn't attach it to this post, the file upload wasn't working, so here's a link to it on my Google Drive:
https://drive.google.com/file/d/1DQg...hiqIJaSe3/view.
