Since its Zero degrees, I left the car outside to get EGT down as low as I could. Base setpoint is 1050 at 3 degrees F, and 1025 at 25. The desired idle Starts at 1200, which seems a little high, and does not match the desired idle from the table.
Where is the extra 150 rpm of desired idle coming from?
