Results 1 to 4 of 4
Thread: L83 Tahoe
    Apr 2014
    11
    L83 Tahoe
    Would someone care to look over my tune and see what they thank. Dod delete with L8t cam Ive done a little timing and pe adjustments. Bluecat tables for trans it runs out pretty good every now and then has a slight hiccup before a shift or coming out of the hole. Im wondering if I dont have my MAF and VE dialed in perfect or if I need to work on torque tables some.
    Tuning Addict
    Jan 2015
    6,858
    You can change your pedal and delay settings for PE, but other than that from what I looked at it didn't look bad. I didn't look at a whole lot in the tune, but from what I did look at and from the looks of the log, I'd say you're doing good. You do need to log more airflow wise and your MAF curve should be smooth instead of having the bumps up top, but other than that.
    ~Greg Huggins~
    13,585
    PE itself is a little fat and the timing when you did go full throttle is pretty low. Like after one of the shifts it's at 8 degrees. You should be able to see low 20's for timing and have it go right back to that after the shift.
    Apr 2014
    11
    I worked on VE and MAF some more I believe its pretty good now. Im still a little rich way up high overall seems to run a lot better. I do have a really short lean spike at shifts and rolling in the throttle but seems like this could be wide band delay from what I have read? Im still pretty low on timing on most shifts around .60 airmass should I add a couple of degrees in the .60 and up area and log it and see if I get any knock?
