Results 1 to 14 of 14
Thread: LS1 Overheating due to Tune?
    Jan 2024
    3
    I've blown 2 LS1 motors this last summer road racing a 2000 Camaro stock LS1 that overheated to 240F+.
    Examined the tune, the AFR modifers had been set to 80 at higher rpm's (3000+), equals an AFR of ~11.7 (pig rich), with advanced timing.
    Would this cause the motor to overheat after about 10-15 mins of racing hard?
    Thanks.
    Aug 2009
    Calibrating
    3,373
    Sounds like your coolant system isn’t up to par
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jan 2024
    3
    Custom radiator box with 16” electric fan. Usually runs at 210-220F, but was a hot October day on the plains in Colorado. 90F with track temp of 115F. Just wondering if the tune that was in the car with hot track conditions cause the higher motor temps.
    Granted I should have pulled up to save the motor, but I was leading the race. What’s a guy to do?
    TIA.
    Nov 2017
    1,467
    Depending on what blown means, it might have blown first and that caused overheating.
    13,565
    Needs bigger radiator and more fans if the temps are still getting too hot.
    Jan 2024
    3
    Appears to have spun a bearing as cylinders 5&6 were damaged. Not sure if the heat caused that but it was running at 245F.
    Thanks for the thoughts.
    May 2014
    USA
    448
    is this coolant temp or oil temp? if 240 coolant, then likely oil was much hotter, unless you have oil cooler?
    if you cooked the oil, bearing damage wouldn't be too surprising.
    doesn't seem like it was tune related, but not nearly enough info in the original post for anyone to really say. Post the file if you can.
    Aug 2010
    Detroit, MI
    932
    Stuff like 'custom radiator box' makes me raise an eyebrow. But in general...the toon can't do much, especially relative to stock settings. They're about as resistant to overheating as you can get. Either upgraded cooling system or derate....those are your options.
    Aug 2016
    Swansea Wales UK
    186
    Check the electric fan actual pulls air through the rad, sometimes pushers are fitted behind the radiator and cause this problem as it hit's the higher temps
    Gen3 L59/4L60E LS3 cast manifolds, Small Cam change, 2800 Convertor, MPVI, using MTX-L for wideband tuning
    Aug 2006
    5BA8
    3,256
    Does the car still have the wicker bill underneath? The lip that hangs down? If you pull them off these cars they run hot. That's the only means of getting air up into the radiator.
    EFI specialist
    email=[email protected]
    Tuning Addict
    Jan 2015
    6,816
    This is exactly what I was thinking. The ol' chin spoiler that everybody likes to yank off that's especially designed to pull air through the radiator at high speeds.
    Sure a tune can be setup to pull timing and derate to help, but if you keep ignoring the temp gauge screaming at you, then not much is going to help. Oil brand and weight will have as much to contribute as the tune can. Rich fuel will actually help to keep things cool, but timing needs to come out with heat.
    ~Greg Huggins~
    Aug 2006
    5BA8
    3,256
    Biggest thing for 4th gen F bodies if you want to road race them is you need the Improved Racing oil pan baffle and you need a good oil cooler.
    EFI specialist
    Mar 2022
    Indiana
    2,954
    Also, crossover/steam vents not clogged or deleted? Could have air pockets.
    Nov 2006
    2,747
    Quote Originally Posted by randyeng77 View Post
    Thanks.
    are these stock LS1's? or strokers etc?
    I'm betting a oil cooler would help tremendously.
    All my road race customers have oil coolers. We made a bolt in kit for the C5's that knocked like 40 degrees off our test car.
    Tuner at PCMofnc.com
