Results 1 to 20 of 20
Thread: LB7 LML Allison Swap Results
    Advanced Tuner Lost0187's Avatar
    Oct 2021
    Canton Ga
    228
    Have had the LML Allison in the 02 Duramax for a few months now with zero issues truck has been performing great and making trips from North Ga to Florida and back 5 times now as well as a lot of normal around town driving. Have done a decent amount of hauls with the 4 horse as well as the 30' goose neck and enclosed motor cycle trailer all have shown great results with the way the transmission shifts and keeps cool most of the time it wont go over 165 degrees.
    Here is a log from around Christmas when I was playing with the lockup on the stage 2 converter don't mind the oil pressure I have to replace the connector.
    This Project has been fun and im always improving on what I've learned and how the driver wants the truck to react. Milage is around 18-22 city and 24-26 hwy around 70 to 80 mph Engine calibration is spot on and has not limped the LML trans yet. Even on hard pulls the truck is all there vs the stock calibration it originally had pushing the lb7 to around 3800 to 4000 RPMS and it pulls hard when asked to.
    Normal driving feels as good as my uncles 2015 LML which is surprising considering that truck is 13 years newer. But it just goes to show when you have the parameters set the way they need to be old vehicles can run as good if not better than new vehicles and not need all the stuff the newer visions require to stay legal.
    Next time Im out in the truck Ill record another new log with all the current updates to the trans calibration and engine.
    Jan 2006
    DFW
    258
    I am really considering doing the 6 speed swap to my LLY. I posted in the other thread and had some questions for you. Thanks for sharing.
    2008 Denali XL AWD LSA Blower
    2010 CTS-V
    2005 LLY Duramax SAS
    2015 Denali
    Oct 2021
    Canton Ga
    228
    For sure ill add some more info and logs as soon as i play with my little brothers truck again. I also have to finishing wiring up that LML transfer case have all the stuff and a gen 1 and gen2 transfer case module to see if I can use the newer version with the 02-07 4wd switches should be fun love wiring lol.
    Jan 2006
    DFW
    258
    I bought today a 02 allison to put in my 05 LLY. Need to know what valve body to find and what wiring needs to be done along with config files when you get time please.
    2010 CTS-V
    2015 Denali
    Oct 2021
    Canton Ga
    228
    You need to get either a 11-19 VB or a 06-09 either can work I have an extra LML VB and harness if you are interested. I could set you up with the complete drop in package and tcm to go with it or send you a flash file once the correct parts are installed. PM me for more details I’d be happy to help you out.
    Our truck is doing great just added some more power to it and everything is working out great.
    Oct 2021
    Canton Ga
    228
    Come to find out a couple people are claiming you might be able to use a 17-19 VB which can save some money msrp from gm is $700 for the 11-15 VB and only $375 for the 17-19 VB not sure why the price difference is, but it should work. The 2 valve bodies seem the same to me & look identical. There isn?t much info on the newer valve bodies other than they now use a main modulation solenoid like the gas autos have. My personal opinion is right off the bat buy the blocker for that solenoid and it will make a huge difference as well as the calibration needs to be set to the specific truck. The one cal fits all is never gonna be perfect it will work but there are always be improvements that can be made on it as with all things.
    You will still have to make modifications to the internal harness for the VB to function properly but this is the main starting point to making the 5 speed transmission a 6 speed
    Also if you have a 01-03 Allison you will not need the shorter front right bolts. But the 04 and 05 guys will due to the g solenoid plate it will damage the case using the longer bolts in that VB in the front right.
    If anyone needs help just let me know have done a few of these now and can try to assist. But I will say the calibration is everything or you?re gonna burn up your C3 clutch.
    I also suggest the C3 oiler modification and PTO covers that direct the extra oil to the C3.
    Oct 2021
    Canton Ga
    228
    Here is the blocker for the 2010 and newer VB and the C3 oiler modification as well as the proper jig to do the oil redirection mod.
    I?m still not 100% sure the 17-19 VB will work so I don?t wanna say I?m sure it will but I do know the 10-15 and the 06-09 Will work with no modifications to your 01-05 LCT1000 cases.
    People might think it?s a 17-19 VB but unless they can confirm the part number on the valve body I can?t guarantee that will work.
    Oct 2021
    Canton Ga
    228
    One other upgrade while you are playing with your Allison might be to upgrade the torque converter I will say I have had 2 florida torque converters 1 their stage 1 and the other the stage 2 they have held up great and hold the torque without any issues. We regularly are shifting the trans at around 3800 to 4000 rpm’s and pulling decent size gooseneck trailers up good size grades in north ga and have never had the trans get hot usually on the highway it stays around 150 to 160 degrees and the highest I have seen in that truck is 185 to 190 in heavy stop and go traffic.
    As for a stock update to the converter you can do the 11-16 oem muti clutch converter it will help with economy and hold the torque better than the weaker 01-05 units that came in the hds at the time.
    Jan 2006
    DFW
    258
    Have you had to change anything pressure wise anything in the file to run the newer valve body?
    2010 CTS-V
    2015 Denali
    Oct 2021
    Canton Ga
    228
    Absolutely if the adjustments are not properly made the clutches will start to slip and you will eventually have a bad day a a ruined Allison 1000. Its a delicate balance with this transmission and its programming especially on these older TCM's. The power level of the engine you need to take into account as well as ay modifications you have made to the transmission. Stock this transmission is one of the best light duty diesel tuck setups & one of the most durable, its once you start to add power to the engine that it can start showing premature ware if the calibration is not spot on. Also wat to add every truck is different truck A might need something that truck B might not and vise versa.
    King Ranch Expedition 5.4 3v 6R80 Coyote PCM , M112 Blower, Kooks Long Tube Headers, Green Cats, Aeromotive Regulated Return Fuel System, ID 1000 Injectors, Custom Interior Wiring, Track Apps, EPS mode adjustable, +6 Blower Pulley w/ Innovators West SFI Balancer, Afco Dual Fan ZL1 Heat Exchanger, Flex Fuel E85 0-60 5 secs 12.0 best quarter mile time.
    14 GT500, 13 Mustang Custom, 03 Aviator 4x4, 16 Navigator Reserve 4X4
    Oct 2021
    Canton Ga
    228
    Our D-max is actually going on another Florida haul tomorrow Ill ask my little brother how it does with the current calibration im running in the truck. I took a ride last week with him for some logging ad I have to say the truck is feeling great. The shifts were firm yet smooth depending on the pedal position. Hwy driving was near perfect as well as the stop and go city driving I really like the Duramax and all it has to offer especially for a older truck.
    Now if we could just get HP Tuners to give us a selectable shift on the fly set of calibrations it would be one of the best platforms in the diesel world just such a reliable truck.
    Oct 2024
    Nova Scotia
    forgive me if I should make a new thread instead of hijacking this one. It just seems close / relevant enough to continue here.
    Running a stock LMM. Have had a hard time sourcing a transmission for it. Last one I picked up I later found out had spent some time in the Atlantic Ocean and got just over 2000 miles on it before losing 2nd gear.
    I was able to find an LML transmission, but now here I am not wanting to burn that up.
    Calibrated it with my scan tool, took a scoot up the road. feels stupid smooth compared to the last one.
    Before I drive it, anymore. Looks like I need a programmer and to enlist your services
    Stock engine / stock transmission. On the hardware side of things, any modifications I have to do for this setup? or strictly programming modifications?
    thanks in advanced!!
    Oct 2021
    Canton Ga
    228
    Just give me a shout I would be happy to help.
    Oct 2021
    Canton Ga
    228
    Just a update this truck is still on the road performing flawlessly my little brother drove it up again from Florida last week for Christmas and is now using it as a farrier rig for his horse shoeing business. The truck flirts with 26 to 28 mpg o the hwy and never misses a beat. I had to turn down the engine side a little to keep the truck in line with what it is a working vehicle not a race truck which a lot of guys forget these thing are built to do. I'm still selling my YAK PERFORMACE LLC swap kits for guys just wanting to make a easy change from 5 to 6 gears in their 01-05 LB7 & LLY trucks. Depending on the year vehicle different parts will be shipped all with the same goal so you guys ca unlock 6th gear and give you GMT800 a more modern feel while increasing efficiency & longevity of your Allison 1000 transmission.
    Jan 2006
    DFW
    258
    Mine is still working flawlessly as well! Appreciate all the help!
    2010 CTS-V
    2015 Denali
    Oct 2021
    Canton Ga
    228
    Sweet Nick been sell them so far everything has been perfect. Even the original tester the 02 Duramax with the LML trans swap has been flawless. Working on a 2009 C4500 Kodiak at the moment with EFI Live annd whoever messed with it prior did a OS swap but didn't do any wiring changes so a lot of weird shit was happening. He reached out to me after a lot of shops turned him down and would push him away and we have since got the proper OS in the truck and the transmission shifting properly. Truck still has some small wiring issues im helping with remotely but other than that all his normal functions are back to normal.
    Sep 2021
    13
    Do you know how to code the IQA codes on the injectors? I have a 2017 L5P in a 86 squarebody. The ECM is unlocked and tuned to eliminate the BCM, etc. Got some water in the fuel and it started belching white smoke under load after I cleaned all the fuel up. So, I replaced all the injectors and lines, but I don't know how to get to the IQA codes.
    I was told to "use VCM scanner and select 'perform ECM swap', and when prompted about the original ECM, choose 'no'. Then, follow the prompts to program the original information to the GPCM again."
    First, there is no "perform ECM swap" function AFAIK, unless he means "replace ECM"? Also, I don't want original info to the GPCM, I want new IQA numbers to the existing ECM.
    Any thoughts? Sorry for the hijack and Thank you in advance.
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    488
    Quote Originally Posted by rs6 View Post
    pretty sure you need to have GM do it or you can get a VCX nano and a subscription to SPS and do it yourself
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    Feb 2025
    How do I get a swap kit for my 2003 LB7 kodiak c4500?
    Quote Originally Posted by Lost0187 View Post
    I have a 2003 chevy kodiak LB7 Allison 5 speed and would like to know more about the swap kit. I also have a 2011 Chevy 3500 6 speed Allison I swap in with the right parts and tuning?
    Thanks,
    James
    Oct 2021
    Canton Ga
    228
    The swap kit is complete with a new OEM GM Allison VB also depending on your year there will be a few other add on parts. The TCM can be included as well for a refundable core charge but I would rather have the original TCM shipped to me prior to sending the kit so I can update and load the proper calibration per VB used. A lot of time I supply cores and don't get them back. Honestly I don't know why when I can refund the customers their core TCM cost. I include as well as customer support and updates down the road as changes are made to the transmission or engine.
    Now another thing I offer is just parts of the kit which no one else is doing, if a customer wants to source their own VB that's fine as well I just need the TCM and the VB harness used to modify for proper operation. The VB has to be from a 2006-up for everything to work properly.
    You guys can contact me any time I'm based out of North Ga in the mountains and have done tons of testing and building to give you the best finished product I can which is everything to me.
    Hope this helps,
    YAK PERFORMANCE LLC
