Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Help 2007 procharged 5.7 hemi ghost throttle and something is pulling timing away
    Jun 2019
    8
    hello my car continues to accelerate after letting off throttle i have to shift into neutral then back in drive to bring rpms back down.
    also seems as though when at wot its not switching to the wot spark table it stays at 5-6 degrees of timing when iam commanding higher
    mod list
    forged 5.7 hemi
    ported heads
    cammed
    d1x procharger
    on pump e85
    5.7 PROCHARGER.hpt
    012124 3RD TEST PASS.hpl
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    your idle MAP is much too high.
    Take a look at your BOV.
    switch off sensed MAP
    Try this out and see if it helps with your issue on it pushing.
    Aug 2006
    5BA8
    3,316
    Looks like a BOV problem. At the end of the run the throttle blade goes back nearly to idle position. It's not like it's hanging open.
    EFI specialist
    email=[email protected]
    Jun 2019
    8
    ok i will try this and report back if it helped or not i will also double check the blow off valve.
    Aug 2006
    5BA8
    3,316
    The D1 kits come with the little generic BOV. You need a big "pro" style one. I never use the ones that come with the kit. I always upgrade to a larger one.
    EFI specialist
    Jun 2019
    8
    i forgot to mention it does have the big red race valve installed
    Aug 2006
    5BA8
    3,316
    Quote Originally Posted by Hemipheen View Post
    If that's the case make sure it's open at idle. Should be wide open. Id it's not you may need to pull the spring out of it and cut a spiral out of it. That's not uncommon to have to do.
    EFI specialist
    For the price, that seems pretty sad
    2019 challenger rt
    k&N cold air intake
    92mm hellcat throttlebody
    ported 392 intake manifold
    ported eagle heads
    Cammotion custom 222/234 cam
    stainless works long tube headers and catless mid pipes
    3' catback with h-pipe & pypes violator mufflers
    e-85 tuned
    3.70 lsd
    Jun 2019
    8
    ok i tried your file and i feel it idles better and part throttle is better i think it got slightly better but throttle still gets stuck at wot.
    I also double checked the blow off valve and it seems to be working properly its wide open at idle and closes when i blip the throttle.
    i have a new log of wot pull5.7 procharged ghost throttle.hpl
    5.7 PROCHARGER try this.hpt
    Aug 2006
    5BA8
    3,316
    Do you have the stock unmodified tune file for this?
    EFI specialist
    Jun 2019
    8
    yes i do here it is
    COMPLETELY STOCK TUNE FILE.hpt
    Aug 2006
    5BA8
    3,316
    I don't know what it is but there's a whole bunch of shit I'd put back to stock and go from there. Lots of TM stuff, DFCO, several things that all could be contributing to it. I haven't seen one of these do this in a while. Used to see it a lot more back in the early days of Dodge tuning.
    EFI specialist
    See how you go with this.. Based on the tune you posted in your original post... Your tune needs work but this may solve your throttle issue.
    5.7 PROCHARGER Give this a go.hpt
    Aug 2006
    5BA8
    3,316
    Quote Originally Posted by Bullet300 View Post
    What about the throttle hang when it's under 3600 RPM?
    To the OP. Who is doing your tuning? Have you considered putting most of the file back to stock and starting over with the basics? Injector data, P ratio axis change for boost, MAP sensor values, etc.? That's what I would recommend doing. There's way too much shit changed that collectively can be causing you problems.
    When I have problem cars come in my shop, ones like this, if the customer does not have the stock file these always get flashed back to stock using a factory tool. Then we start from scratch.
    EFI specialist
    actually removed that post... not going to be posting here to help anyone anymore.. Think you guys are in good hands
    May 2018
    Germany
    586
    Wow…my Google search says :
    Voluntarily, unsolicited
    That’s what it is.
    Oct 2016
    Poland
    1,750
    Not acting like a smart ass...even tho I frequently do...all them files no good
    Aug 2006
    5BA8
    3,316
    Sounds like I missed some drama or something.....
    EFI specialist
    Jun 2019
    8
    i had some time today to mess with the tune and found that turning off sensed map fixed the throttle hang issue and drivability is alot better.
    but still has problem where at wot it seems to be using the min spark table.
    012424 PROCHARGED SENSED MAP OFF.hpt
