Results 1 to 5 of 5
Thread: 5.3 Tune - Engine Has Several Mods
    Jan 2024
    4
    Question 5.3 Tune - Engine Has Several Mods
    Hello-
    A VERY new Newbee here.
    Trying to get a base tune on an engine so that I can hand it over to a tuner to get it 100% right.
    Some info -
    2004 5.3 GEN 3 cast iron truck motor.
    bored to 5.7
    CAM - 275/277 seat duration, 222/224 duration at .050? lift, .566/.568 lift, and 112 LS. matching springs/retainers
    10.5 compression
    blue printed and balanced
    performance valve job some
    Ptr Carbon fiber intake
    Holley EFI Terminator X Fuel Injectors 522-428X EV6, 42#
    58# fuel pressure at the rail
    90mm gold blade new GM throttle body
    PSI special cable to go from factory 8 pin TB to a 6 pin TB.
    The wiring harness and computer purchased from PSI - delivered with a factory 5.3 base tune. the 55' pickup had a stock 5.3 motor and put in the new one a week ago.
    Two items I changed - idle values and injector flow #s (used 58/43.5 SQ root times 42#)
    started truck today and broke the motor in -
    not running rich. ran well for the most part.
    Issue I have -
    1. once the engine is at or above 195 degrees , if I step on the gas pedal to raise up to couple thousand RPM, if I quickly lift my foot off the gas pedal the RPM will drop way below the 875 value in the table and engine will quit and/or severely stumble
    If I hold my foot on the pedal and slowly lower rpms till they are near 875 and let the engine settle in, it will not quit and holds the idle nicely.
    I figure this WAY beyond where I am right now and if I start screwing around to much will make things worse I figure - LOL
    Just looking for a push in the right general direction -
    I just need it to run decent enough I can drive it (for tuning) and get it to an alignment shop.
    Thanks in advance
    Bill
    Sep 2021
    475
    Do yourself a favor and buy a injector set with gm hpt data.
    Mar 2009
    Andover, MN
    457
    This.
    But no one can help without a Tune let alone a log with the tune.
    Jan 2024
    4
    I will be posting the HPT file and log in the am tomorrow.
    Laptop is at the shop
    Thanks. Bill
    Jan 2024
    4
    Hey ...
    I figured things out.
    MAF and Idle Airflow were all sorts of screwed up. plus a handful of other small things.
    Idles like a charm now -
    I can take it to the alignment shop and get a tuner to work out all the fine tuning items ---
    Thanks - Bill
