I've been working on cleaning up my "return to idle" from a free rev of the engine at a stop. I've got a bit of a RPM dip on the return to idle and I've been trying to attack the problem without much success.
Oddities/Questions:
- I've been unable to get a "delay" in the throttle follower. Setting the delay (to 1 sec, for example) in either "P/N" or "Gear" does not delay the decay of the TF airflow. Is this known/common on P59 C5 operating system? Is there something I'm missing?
- This one is a little less an "oddity" perhaps.. Doing some math to derive the decay rate I'm seeing in the logs, it appears the ECU is using the "Gear" tables (for both Delay and Decay?) despite the car being stationary and in Neutral. The calculated decay rate isn't a 100% match to the decay rate in the table, but I attribute this to the limited sampling rate of the logger as we are in the ballpark. Do these ECUs ignore the "P/N" Decay/Delay?
Attached is the Calibration:
read_01232024rev1.2.hpt
