I have a 2010 Tahoe 5.3 (LMG) with the HD trailering package (8200lb rating) and occasionally tow a 7500lb trailer. It has 170k miles and is currently running and shifting well. I recently purchased an MPVI3 for this vehicle and want to do the following:
-Disable AFM
-Disable flex fuel. I only use regular gas, but I had a problem in the past where the fuel alcohol level got very high for an unknown reason and caused the truck to run rough and required a fuel alcohol reset.
-Make changes to the transmission calibration for longevity. I understand the torque converter is the weak point on these transmission so I've heard many will disable the TCC in gears 1-4 to prevent wear.
When I tow I use the tow/haul mode button. I understand that this will keep the trans out of 6th gear in an effort prevent the torque converter from going in and out of lockup.
My questions:
-Is disabling the TCC lockup in gears 1-4 a good idea for heavy towing? How about disabling slip completely in 5-6 gears?
-Since I use tow/haul mode, does this mean that I'll also need to make the changes to disable TCC lockup in Pattern A?
-Are there any other transmission calibration changes I can make in an effort to get the most life out of my transmission?
-Are there any other good or commonly used changes to the engine calibration that would help in general or with towing and/or longevity?
