Results 1 to 11 of 11
Thread: Graph Column Sizing
    Mar 2009
    Andover, MN
    485
    Graph Column Sizing
    For the life of me I cannot figure out how to get the columns wider to view larger numbers. Ive searched and reread through the Help section. Ive also tried reducing the text size through windows from 150% to 100% and that did not help.
    Aug 2021
    550
    Quote Originally Posted by ns158sl View Post
    What happens if you right click the chart > Display Properties and then change the font and point size?
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    Mar 2009
    Andover, MN
    485
    Just tried it. Same thing. Atleast the numbers are bigger now lol. But still abbreviates it.
    Tuning Addict
    6,829
    Usually the scanner autoscales for larger numbers. You could try changing the decimal places to something like 4 or 5 that way the smaller numbers would be longer and then maybe you could see the bigger numbers.
    The DD tool works really well if that's what you're trying to log for...
    ~Greg Huggins~
    Mar 2009
    Andover, MN
    485
    Yeah I was going to try the tool on my old mans gen V. I tried adding decimals, then it autoscales the smaller numbers with a bunch of "...." also. Ill send a ticket in and see what they say.
    SoCal
    1,578
    May want to change this. Right click on the desktop and go into display settings.
    Mar 2009
    Andover, MN
    485
    I tried the text size before but I tried both just now like you listed and still the same thing. I sent a ticket in but im sure I wont hear back until monday if im lucky.
    Mar 2009
    Andover, MN
    485
    Support says they havent seen this issue before and wanted more logs. So we will see if i can get any more and send. Just seems odd.
    Tuning Addict
    6,829
    I actually noticed this problem on my other computer running the newer beta, so something they changed in the software. Good luck with the hpt help run around. It'll go on for a month of so then you'll pretty much have to live with it cause you'll get tired of the back and forth.
    ~Greg Huggins~
    Australia
    1,987
    might be a computer thing, just tried the stable and beta and both i can see over 10000 on the counts so should be able to go to 99999 without issues on mine
    Mar 2009
    Andover, MN
    485
    shoot. Well thanks guys for verifying. Ill have to export to excel until I can figure it out.
