Originally Posted by
hjtrbo
Don't worry about my temp test. You're getting temp.
There is a min throttle condition they'll keep you out of lock up. You might be onto something there. But I would say that if the min airflow is such a high value it keeps you out of lock up then that needs to be researched as to why you're having to do that.
I'm away for a few days so can't look at your files.
I'll have to let you decide if the mis fires are cam related or if there's a genuine issue there. It's not normal to see those numbers you're getting. There are misfire test tables you can tweak if cam related.
