Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: How many of you guys are tuning with Narrow bands on Idle and light cruising
  1. #21
    Aug 2006
    5BA8
    3,301
    If your airflow tables are dialed in +/- 5% there's no need for long term trims.
    EFI specialist
    email=[email protected]
  2. #22
    Jan 2023
    254
    Thanks for clarification guys. I'm going to turn LTFT off and likely leave them off and tune with STFT
    Seems way easier and may explain why I was having trouble dialing things in.
    Which is why I asked about using the wideband.
  3. #23
    Jan 2023
    254
    Quote Originally Posted by Cringer View Post
    I just turn LTFT off and keep them off. If you are ever "done" with tuning then turn them on. But the hard part of tuning, logging, revising the tune, driving, logging, etc is that you need to reset the LTFT learned values in the scanner before you drive and log each time (at least if you are making air/fuel changes). This is easy to forget and adds extra time and steps to the tuning process. And if you forget, then the potential for error starts to creep in your tune which will delay final results and have you going in circles.
    The other argument is that the last LTFT value that is active will be carried forward into PE fueling. I have seen this happen on my E38. Which then throws off your attempts to calibrate PE air/fuel.
    Just re-reading this post, this may seem like a dumb question, but if you turn LTFT off in VCM editor, you don't have to reset LTFT every time you flash, log and drive?
    I'm assuming if you have LTFT's in your channels it will just have a value of "ZERO" when turned off?
  4. #24
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    534
    Quote Originally Posted by Allen Vos View Post
    Correct x2
    A standard approach will give you standard results.
    My Tuning Software:
    VVE Assistant [update for v1.5]
    MAF Assistant
    EOIT Assistant
