Results 1 to 8 of 8
Thread: rpm drop lower than idle after throttle release
    Aug 2023
    15
    hello everyone.
    i have noticed that while in park if i rev engine normally(1500-2200rpm) then let off the throttle, when the rpms come back down they drop to about 500-600, the engine will "stall" for a split second, the interior lights will flicker, then rpms come back up to normal idle range (750-900rpm)
    i would like to know where to start looking to solve this problem. is it deceleration fuel cut off?
    i havent done a log of this situation yet, but i will attach my tune file
    could this be a vacuum problem? the cam is a 107 lsa.
    Aug 2021
    846
    Probably need to add more airflow in the 500-800 range.
    Aug 2023
    15
    Im new to tuning and hp tuners, i checked every chart under airflow, but i didnt find anything to do with rpms.
    Would you be able to guide me in the right direction?
    Aug 2006
    5BA8
    3,253
    Idle/Airflow/Base running airflow final minimum.
    EFI specialist
    email=[email protected]
    Aug 2023
    15
    Thank you!!
    Nov 2006
    2,742
    Quote Originally Posted by Ludlow View Post
    hello everyone.
    This is often cause it is going too rich when you lift off the throttle. Or the airflow models are incorrect.
    Tuner at PCMofnc.com
    Aug 2023
    15
    what do you suggest i do? i attached my log in the post, do you see anything strange? i checked the airflow final minimum as edcmat suggested. but it seemed pretty smooth.
    Advanced Tuner morepowerjoe's Avatar
    Sep 2021
    Austin
    292
    How about a list of your mods with cam specs?
    L99 A6 - DSS FX Forged Piston's, Eagle ESP L19 Rods, ARP Head and Main Studs, LS9 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnion Upgrade, TSP Chrome Molly Pushrods, BTR .660 Valve Springs, GM Hollow Intake Valves, Melling 10355HV Oil Pump, IR EGM-205 Oil Pan Baffle, CAI Intake, Fast LSXR Intake Manifold, Nick Williams 103 TB, ZL1 Pump, TSP 1 7/8" Longtubes with 3" TSP Exhaust, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter
