Results 1 to 2 of 2
Thread: TPS value in scanner sweeping between 0 and actual tps several times per second
    Aug 2020
    6
    Hello,
    I have a vehicle here that is acting up. Tps signal oscillates rapidly from 0% to actual% then back to 0% several times per second when LIVE. Reviewing a log the values are cut in half. Attached is the two logs and a screenshot and the tuneup
    7,816
    Trouble Codes:
    P0122 - Throttle/Pedal Position Sensor A Circuit Low (Pending, Current)
