There are 2 RPM values in the PE chart.
There is one in the Delay Section and is set to 5000 RPM but the delay is set to "0" so all values in the Delay area wont ever activate.
The other one is in the Enable section. This is the one I was speaking about.
You can set this so to whatever min Rpm you would like the PE to come on.
I was just wondering what a good RPM was to use? What are all you guys using?
From the factory mine is set to 300 RPM with 15 KPA on the map enable and no delay so it seems like PE was going by the TPS percentage chart and PE would come on at like 19% throttle.
Seems weird to have it on pretty much all the time.
Attachment 142846
