Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: 05 Burban with stock 5.3 truck norris camshaft
    Sep 2020
    18
    here is what i got. i slapped a camshaft in the stock 5.3 motor in my 05 suburban z71 flex fuel. i had a decent tune in it for over 2 years. ran decent. i built another stock 5.3ls to replace factory motor. only part that is different between the 2 motors is the valve springs. i went from stock to .600 in valve springs. now the tune i had in before engine swap wont alow motor to run correctly. wideband and vcm scanner show motor running to lean & i cant seem to get it away from being lean. any help would be great. DERICKS TUNE NEW MOTOR..hptDERRIK BURBAN NEW MOTOR FIRST DRIVE.hpl
    Nov 2017
    1,489
    If there are no differences between motors other than valve springs, problem can't be in the tune. You have other mechanical/electrical issues.
    Sep 2020
    18
    Motor runs smooth. Other than being lean on fuel. Log data to me shows only a lean fueling issue. I changed tune back to stock from factory before cam swap with factory motor. Truck now runs much better with being lean still but no where as lean it ti was before. I will upload another log file. ( all log files are with out any driving due to be lean). Does any thing in my log file or tune file look off?
    Nov 2017
    1,489
    I can't review files on this computer. But are you now saying this is a different "cam" on a different tune?
    Sep 2020
    18
    i am still running the truck norris cam. just used the factory tune for stock motor. but i am still running lean. inputs n my tune or log would be helpful. i understand you cant see them at the moment
    Why are you only logging LTFT for Bank 1? Start logging both STFT and LTFT for BOTH banks. The one bank shows you are seriously lean... have you considered a vacuum leak somewhere? Try logging BOTH banks and lets see if there is a variance between the two banks. Either vacuum leak, or exhaust leak before O2 sensors can cause this. As mentioned above-just changing valve springs should not cause the lean condition you are seeing...
    Sep 2020
    18
    i will change log data and do a log sitting at ide. i dont ant to drive it anymore than i have to untill i figure this out
    update log file at idle found short term fuel trim to be exact opp of each bank. vacumm leak cause this?
    Sep 2020
    18
    update log file
    here is update log file with short term fuel logged for each bank
    Aug 2006
    5BA8
    3,284
    If it's showing lean and you can't seem to get it to richen up the logical thing to check is your fuel pressure. Everyone always wants to fix all their problems by "tooning" instead over covering the basics first.
    EFI specialist
    email=[email protected]
    7,673
    PE Enrichment Ramp-In is 16? Sixteen? In a field that allows a range of 0 to 4?
    Sep 2020
    18
    i have checked all basic engine. plus fuel pressure. lean is only on one bank.
    Nov 2006
    2,751
    You didn't happen to swap a motor with different injectors? Had a guy last week give our sales guys a lot of trouble. He swapped complete engines including injectors and didn't bother to tell us. He just thought 5.3 injectors was 5.3 injectors.
    Tuner at PCMofnc.com
    Sep 2020
    18
    that was a old file i was using i will update new tune file with data logged
    Sep 2020
    18
    i used the stock intake with fuel injuectiors. only difference in motor is the bigger springs
    Sep 2020
    18
    updated tune file and idle log file
    i have started over with the tune file. i will attach new tune file & log data. having troubles on why bank 1 stft is positive and bank 2 is neg
    Aug 2006
    5BA8
    3,284
    You aren't logging your O2 sensors so you're only getting half the story. Looks like it's only running on one bank judging by the fuel trims only. Need to include B1S1 and B2S1.
    It's not going to be a tooning problem. It's gonna be a bad ground on the back of the head or something like that.
    EFI specialist
    Sep 2020
    18
    i will load update log file. o2 bank 1 sensor 1 is staying close to .45 the whole time. see new log file
    Sep 2020
    18
    i will load update log file. o2 bank 1 sensor 1 is staying close to .45 the whole time. i didnt save new log file unfortunately
    Nov 2006
    2,751
    That usually means unplugged or bad.
    Sep 2020
    18
    o2 sensor log file
    at the start of the log file b1s1 &b2s1 is plugged in vehicle not running. unplugged b2s1 and not change in voltage. towards end of log file i unplugged b1s1 and it reads the same or close to b2s1 while its lugged up. will this cause lean on 1 bank and rich on the other bank
