Thread: Flex Fuel map for Ford Fusion?
    May 2021
    Between Florida and Michigan
    50
    Can someone share a (oem) map from a Flex Fuel Ford Fusion??
    Mine is a (base) 2014 Ford Fusion with the 2.0 Ecoboost motor and automatic transmission. And I am interested in modifying the base tune to run flex fuel.
    Thanks!
    Oct 2023
    None of the eco boost are flex fuel oem. I believe even e30 and e 85 tunes are not flex fuel but dedicated to that blend.
    Tuner Camaro6's Avatar
    Jun 2018
    Chicagoland
    135
    Quote Originally Posted by DPatience View Post
    I disagree. Flex fuel on 2020 Edge ST without any issue for 4ys and 30k+ miles. Done it other models as well with great results. It can be done if the tuner is smart enough to figure it out. My pump E85 here is E70-E75 typically and run that normally and will put 93 in if needed when out of town. I tell my wife to put anything in it, doesn't matter. It works on a sliding E content scale for parameters. Ford tuners arguing with me back in 2020 have no clue. I've not looked over a Fusion tune, but I'll venture to say it's doable considering what I know on other models.
    OP: you probably won't find a factory tune already set up for flex fuel.
    2018 Camaro SS, LT4 Fuel System, LT4 S/C
    2020 Ford Edge ST (93-E85 flex fuel tune)
    1999 Pontiac Firehawk
    1987 Chevy Caprice, 6.0L TT 4L80 AWD
    ***Only AWD box chevy in the world***
    Next Level Tuning and Performance
    Tuning email: [email protected]
    May 2021
    50
    Thanks!
