Page 3 of 7 FirstFirst 1234567 LastLast
Results 41 to 60 of 122
Thread: 04 silverado tune
  1. #41
    Banned
    Mar 2022
    Indiana
    4,289
    What was changed exactly? Stock manifolds?
  2. #42
    Oct 2022
    North Carolina
    83
    Just put on stock muffler. thats it still has the headers .
  3. #43
    Oct 2022
    North Carolina
    83
    Truck was to loud and had to hear the neighbors cry.
  4. #44
    Banned
    Mar 2022
    Indiana
    4,289
    Check out black widow exhaust. Best sounding I've heard on a truck, and they're cheap. Quiet idle, but they sure get loud when you want them to. They even have a 'Neighborhater' model lol.
  5. #45
    Banned
    Mar 2022
    Indiana
    4,289
    Quote Originally Posted by Jamescorbett View Post
    I had to change the exhaust and go back with stock style and the numbers were crazy on this run i hope that doesnt mess it up .
    Numbers aren't crazy at all. Still have the slow O2 problem. Maybe throw a set of Denso O2's in there like you're saying.
    Here's for now.
  6. #46
    Oct 2022
    North Carolina
    83
    Here's for now.
    I think i have a set that were good on a wrecked truck ! I may try them . Then run a datalog
  7. #47
    Oct 2022
    North Carolina
    83
    Here's for now.
    Will the stock muffler hurt the horsepower?
  8. #48
    Banned
    Mar 2022
    Indiana
    4,289
    Eh idk about that. New.
    It can. We didn't map enough of the upper end of the VE table to tell by how much.
  9. #49
    Oct 2022
    North Carolina
    83
    Before o2's
    I didnt get the o2S changed ,the store had to order them. Which one' or how many do i need do i need to change .I didnt no if it is bank 1 or bank 2. or front or back. I did a run with that new adjustments.
  10. #50
    Banned
    Mar 2022
    Indiana
    4,289
    Denso's from Rockauto. Pair of fronts (upstream) bank 1 and bank 2.
  11. #51
    Oct 2022
    North Carolina
    83
    I ordered them from local store here and got them at a discount cause friend runs a shop and they were 39 a piece Reg 59 . I hope tomorrow i will have them I was trying to get this done fast .
    Is Rockauto cheaper
  12. #52
    Banned
    Mar 2022
    Indiana
    4,289
    Usually. 29 bucks for those.
  13. #53
    Jan 2015
    Arizona
    1,290
    Is Rockauto cheaper
    https://www.rockauto.com/en/catalog/...2)+sensor,5132
  14. #54
    Oct 2022
    North Carolina
    83
    Thanks mine should be in tomorrow.
  15. #55
    Oct 2022
    North Carolina
    83
    Sorry for no updates . I left Friday and stayed in the mountains for the weekend and just got back today . but i will have the o2's tom . But now i have to rebuild a transmission . Mine is slipping in 1to 2 and then i have no overdrive. But i will post a run will i get the o2's . maybe i can do a pull in it .
  16. #56
    Banned
    Mar 2022
    Indiana
    4,289
    Sometimes they come out of it with a fluid and filter change. Run some Seafoam TransTune for a few hundred miles. Then drain as much out as possible by disconnecting the cooler return line to pump the fluid out. Keep refilling and pumping until clean and bright red. Those shop flushes where they douche fluid in and out through the dipstick tube can be damaging. Pumping out of the cooler line keeps the same hydraulic circuit path, so debris doesn't end up crammed in the valve body.
    After that copy the Performance upshift pressure table to the Normal.
  17. #57
    Oct 2022
    North Carolina
    83
    I will give that a try. But we have started to rebuild a transmission that i had that i wanted to bullet proof it . But ill have to wait for that . But i will run the transtune and see what it does. And fluss out the lines.
  18. #58
    Oct 2022
    North Carolina
    83
    transmission rebuild
    This is a run after the transmission rebuild. Has stage 2 kit with the HD shift kit so it shifts hard . But is fun to drive . Im having a problem with rear end noise now got another 373 gear rearend for it . I added a 3000 stall street brawler from jegs . Let me no what you think .
  19. #59
    Jul 2017
    8
    looks alright could use some more timing 22 degrees at 4400 to the shift is pretty low imo 12.2 afr is pretty safe too but with no WB cant say that's accurate so you probably shouldn't get too crazy with timing until you verify AFR
    With the shift kit Id take that timing reduction off on the shift but that's your preference, it could keep the band and 3/4 clutches alive I guess.
  20. #60
    Banned
    Mar 2022
    Indiana
    4,289
    Scanner polling rate is pretty slow. Remove torque, load, and misfire stuff. Don't need B1/B2 S2. MAF stuff isn't needed right now for SD. Trans Performance and Calculated Gear Ratio.
    VE roughed in. Shifting changes applied for your stall.
