Results 21 to 40 of 56
Thread: 2002 LM7 Stalling Issues
  1. #21
    Aug 2016
    Swansea Wales UK
    186
    Are those flex injectors ? usually it's 53psi for the fuel pressure ?
    Gen3 L59/4L60E LS3 cast manifolds, Small Cam change, 2800 Convertor, MPVI, using MTX-L for wideband tuning
  2. #22
    Mar 2022
    Indiana
    2,941
    See I knew there was something wrong after adjusting the VE table. You've got the injector data entered for vacuum-referenced return rails. Now, the actual data has to be correct as well. Do you have that part number?
  3. #23
    Feb 2024
    33
    Which part number are you looking for?
  4. #24
    Mar 2022
    Indiana
    2,941
    Should be an 0280 number on the side of the physical injector if it's made by Bosch. Take a look and see.
  5. #25
    Feb 2024
    33
    They dont appear to be bosch injectors, they say Denso 25326903, i had a set of 32lb knockoff bosch injectors in it originally but decided to switch to an OEM set when i was having issues getting it dialed in, i was also occasionally getting a backfire when turning key on, after engine was hot, this issue hasnt occurred since i ditched the knockoff bosch injectors, i also have a set of OEM 12594512 injectors i could swap in if they are a better option. I believe i pulled the current injectors from a 2002 flexfuel tahoe with the 5.3l, looking the part number up confirms that they were used in that vehicle, looking at a stock tune for that vehicle is showing 33lb/h in the flow rate vs manifold pressure table, information i am finding is saying 33lb/hr at 50psi, compensated for pressure from a formula found here looks like 35.5lb/hr, which was still different than what i had in my tune so i am only more confused now on where i got the 38.6lb/hr
  6. #26
    Mar 2022
    Indiana
    2,941
    I put in the data for a 2002 Tahoe Flex L59.
    Got EOIT info from cam specs here:
    https://forum.hptuners.com/showthrea...l=1#post745257
    See what happens now.
  7. #27
    Feb 2024
    33
    I havent heard of EOIT before, briefly searching it, it looks like it is the fuel injector timing essentially? Noticing huge improvements! Just got a short drive in today, log attached. Greatly appreciate all the help! I am also glad to be getting this set up correctly compared to what i had previously, i mean sure it worked, but i can already tell a huge difference
    12.hpl
  8. #28
    Maybe someone can answer this for me but is it common for the o2 to be switching exactly the same? i do alot of reading and i couldve sworn i read something about if they are the same more than likely an issue or one is cancelling the other.
    like i said i maybe wrong but its fairly fresh in my memory which is why i asked to check the connectors.
  9. #29
    Mar 2022
    Indiana
    2,941
    Quote Originally Posted by tana99ss View Post
    It's how he has it setup. Look back at Post #9.
  10. #30
    Mar 2022
    Indiana
    2,941
    Quote Originally Posted by twenglish1 View Post
    12.hpl
    Have you been using VCM Scanner to clear LTFT after each tune update?
  11. #31
    ah i see it now, i was like thats off , i missread it or missed it completely.
    wouldnt it be best to tune with stft + ltft for driveability then come back and then install the wideband one side and make those adjustments then?
  12. #32
    Mar 2022
    Indiana
    2,941
    Yes, but to run CL is the question. Ideal would be both front O2's and a separate spot for the wideband. This will work for now.
  13. #33
    Feb 2024
    33
    I have not been clearing LTFTs after each update, i will be sure to start doing that, i thought they would have adjusted automatically? or is it just faster to clear them each time, that way its a fresh start at the start of the log? I will be welding on an o2 sensor bung at some point and running both narrowband o2s along with the wideband
  14. #34
    Mar 2022
    Indiana
    2,941
    Yes you should clear them after each tune update. VCM Scanner>Vehicle Controls & Special Functions.
    Try this, please. I did some VE work.
    Oh yeah. Start logging Injector Pulse Width for each bank (Generic Sensor).
  15. #35
    Feb 2024
    33
    Is there a limit to how many channels before i start having issues? i have alot being logged. I had injector pulse in before, not sure why i took it off the channel list, but it is added back, anything else i should be looking at in particular that i might be missing? That new VE looks great, post back when i get to test it out, weather isnt the greatest today
  16. #36
    Mar 2022
    Indiana
    2,941
    Scanner will start to slow down. The number of channels you're polling should be ok. Other than injector pw don't need anything else extra for airflow tuning.
  17. #37
    Feb 2024
    33
    Couldn't get on it too hard, too much rain, but running great for sure! Got another short log here, doesnt look like any changes need made, ill get a better one once weather clears up. I find in incredible that you were able to create that whole VE table just from the minimal parts that i had been adjusting, i mean i understand how VE increases with RPM and MAP, so i guess start with the known area and work out to the extremes?
    14.hpl
  18. #38
    Mar 2022
    Indiana
    2,941
    Haha thank you, but the log shows it was actually still pretty far off. It still will be after this. Takes a few iterations to settle in.
    Exactly. Work out the known area then extrapolate the trends.
  19. #39
    Feb 2024
    33
    Doesn't think i have hit PE on any of my drives yet, haven't gotten to that point yet, do fuel trims need to be omitted if the PCM is commanding anything other than lambda 1?
  20. #40
    Mar 2022
    Indiana
    2,941
    Fuel trims will only work in CL. PE is OL.
