Hello everyone, I'm 3 tuners and countless revisions deep into this cam and i'm at my limit. i've spent the last year and over thousands of dollars diagnosing a ghost. I know the issue is the tune because with every revision it's changed to something else.
I am trying to add my logs but it will not attach them. I've attached the tune i'm currently using.
The current issue, if I let off the gas around 30 or so the car will not decelerate normally. it holds speed for upwards of a mile.
Idling in gear you absolutely cannot have a drink in the car unless you wanna wear it. the entire car rattles.
Coming to a stop the car begins to chop extremely harsh.
if i'm driving in slow traffic and I'm at the edge of 3rd(i think) gear if i don't give the car enough throttle itll surge 300+ RPMS then shift into the next gear. "Fine.. i'll do it myself.."
Otherwise the car drives perfectly fine and has substantial power. i havent given it a WOT pull yet because it's old and i dont wanna walk home but other than the issues above it's the best tune i've got.
2011 Dodge Charger R/T AWD
Comp Cams HRT Stage 2 cam
BBK Throttlebody(think it's the 89 MM or a stock size)
6.4 Intake mani with SRV activated using MMX controller(stock SRT RPM)
K&N Typhoon series CAI
FTI 3200 ESRT TCC
ARH 1 7/8 LTs into High Flow Cats
3 ID Exhaust
20 inch wheels
MSD coil packs(originally installed 5 years ago)
factory spec spark plugs and fuel injectors
SRT primary fuel pump(no reason except it was $90 cheaper than my original)
I drive the car in AWD mode only(sport for RWD model) 93 Oct R8 New Read WITH TCM Adjustment.hpt
