Results 1 to 7 of 7
Thread: Flow Factor - what's the verdict on using this to tune MAF and VVE simultaneously?
    Tuner CYN_CRVR's Avatar
    Jul 2023
    Los Angeles
    60
    I just came across this GRG video from 2 years ago. I searched in this forum but couldn't find anything. Has anyone replicated this method, and how well did it work for you?
    https://www.youtube.com/watch?v=WoXTmdTQkpE
    I have to say it doesn't make sense to me. If I understand correctly, he's trying to solve this equation: (1-FlowFactor)*MAF_error + FlowFactor*VE_error = total fuel trim
    FlowFactor and fuel trim are known, but that still leaves one equation with two unknowns (not enough information to solve).
    I think it also inherently assumes the MAF and VE errors occur in the same direction (both positive or both negative). But consider this scenario:
    - Flow Factor = 50%
    - measured fuel trim = +3%
    - actual VVE error = +8%
    - actual MAF error = -2%
    In this scenario, wouldn't this method push the MAF error further into the negative?
    Jul 2023
    Los Angeles
    60
    This post from Cringer is what sent me down this rabbit hole in the first place:
    https://forum.hptuners.com/showthrea...l=1#post744014
    Aug 2010
    Detroit, MI
    949
    If it seems like it makes no sense, that's because it doesn't. Guy chose a random variable in the scanner, conjured up a hypothesis about how it worked and then etched that misinformation nonsense into history by making a YouTube video out of it. The parameter in question has nothing to do with airflow calibration...don't believe everything you see in a tooner how-to video...
    I can't get that Channel to populate on my car. I tried, but it's not supported.
    Unless I'm missing something in my Scanner, I've used smoke's method since he shared it, and have had great success. I've tried to use Cringer's method and I'm not sure it's any better, but I have a pretty simple combination, so don't take my word. My MAF/Dyn/VVE all align (until VVE and MAF max' out, lol) for where I've been able to gather data. I'm just a guy that plays on his own cars.
    Dec 2023
    15
    you need to visit the SILVER SURFER you tube channel he's very informative about your exact question its well worth looking into
    Jul 2023
    Los Angeles
    60
    Yep, I've just been using Cringer's DynAir formulas. I started out using his VVE Assistant tool too, but have since decided I prefer to simply make averaged changes on a per-zone basis.
    Tuning Addict
    6,872
    On gen V's using dynamic can cause problems or at least it was for me, but my customers usually also want OE drivability. The whole reason I stopped using it was because it was throwing off the decel fueling zones of the VE table which was causing throttle issues. I couldn't figure out a way to filter out decel without losing a ton of the lower VE region worth of data, otherwise it would have worked just fine. GM on the newer gen V platforms uses the MAF to correct the VE tables as an applied correction factor, so even though it does max out on the bigger hp applications because of hpt's scanner limits, I went back to doing it that way - basically just making the VE match the MAF. AND don't get me wrong, all of Cringer's stuff is greatly appreciated, I just couldn't use the dynamic formula on gen V's once I started making everything else closer to OE levels especially via correcting the torque models in particular back to as close to stock drivability as possible.
    ~Greg Huggins~
