Results 1 to 10 of 10
Thread: User Defined PIDs Not Showing Up In Histograms
    Nov 2005
    Houston, TX
    3,968
    Angry User Defined PIDs Not Showing Up In Histograms
    I have two user defined PIDs, one for my AEM WB ported through my AC pressure sensor port, and another for % AFR Error using the first custom PID.
    When I go to define some custom histograms and click on the PID to display, only the built in user defined PIDs show up to be able to choose from (calculated cylinder air, IDC, Air Fuel Ratio Error) as well as my AEM WB user PID but my custom AFR % Error PID does not show up. I thought it had to do with using a % character in the PID or that the PID referenced another user pid number in the function so I created another user PID for AFR % Error which does not use the % character or reference any other user defined PID numbers and that one does not show up either.
    I'm perplexed. Sadly I can't upload my config from behind the firewall at work.
    Bill Winters
    Out of the LSx tuning game
    Sep 2002
    Chicago, IL
    6,395
    What version of software are you running?
    We got this guy Not Sure, ...
    28,268
    close your scanner & reopen it...then report back
    Nov 2005
    Houston, TX
    3,968
    2.1.16.0 or course.
    Bill Winters
    Nov 2005
    Houston, TX
    3,968
    Quote Originally Posted by foff667
    That seems to have done the trick. I think it was because I had two scanners open, one with my old C5 WB config and another one I was creating off of your new LS2 default configs. Closing all the scanners and re-opening seemed to fix it.
    Bill Winters
    28,268
    hehe of course it did...im mister fixit damnit!
    Nov 2005
    Houston, TX
    3,968
    Just duplicated it again. The scanner seems to get confused when multiple instances are open. At least we know the fix now.
    Bill Winters
    28,268
    actually even if you have only one instance open and make a custom pid, you then need to close said scanner for it to be activated for your next session.
    Jul 2004
    1,579
    You never owned CA Plate "mr fixit" did you? I recall seeing that plate on a '68 Camaro RS (it was nicely built) about 10 years ago.
    28,268
    I only wished I owned a 68 Camaro
