Results 1 to 10 of 10
Thread: vcm editor wont open engie-trans-system tabs
    Tuner Onomoto's Avatar
    Aug 2018
    Ohio
    120
    Hello all, 2 days ago adjust some settings in my tune saved the file and put the laptop on sleep mode. Today i opened the editor and and now none of the system tabs for engine- trans- trans-diag nothing will work. I've tried other tunes and also shut down and restarted the laptop. looks like it did a security update while i wasn't using the computer. My laptop isn't giving me a option to revert to a later date neither. Im lost
    2001 monte carlo swapped l67 on e85
    XP cam
    gen5 m90
    NorthStar throttle body
    speed daddy headers 3inch exhaust
    3.0 pulley
    lq4 maf
    cold air filter behind bumper
    60 lb injectors
    7,823
    It might, MIGHT, help you get less lost if you post the file here so someone else can open it and see if they see the same thing you see. You see?
    Aug 2018
    Ohio
    120
    lets try this again
    XP cam
    gen5 m90
    3.0 pulley
    lq4 maf
    60 lb injectors
    28,287
    go to window-cascade
    This will unhide any windows(which is likely the issue)
    Aug 2018
    Ohio
    120
    Bill your awesome that did the trick. Thank you sir
    XP cam
    gen5 m90
    3.0 pulley
    lq4 maf
    60 lb injectors
    Help with Advanced View.. Please.
    Can someone please look at this file and tell me why I can't see advanced tabs? When I saved this file 10 months ago I was able to see all tabs in advance. I tried opening it today to look at some setting and only can see the basic view. I've been reading and trying everything I read with no luck .. This issue is above my head.. 2014 Silverado Knight Original 5312023.hpt
    28,287
    edit-view-set to advanced.
    Thanks Bill, I tried that several times and no luck. Advanced is checked and I would open up the file and can't see all tabs.
    28,287
    post the file and a screenshot of what you are referring to.
    28,287
    file appears to work fine for me that you posted previously.
