Results 1 to 5 of 5
Thread: LS3 coils with LS1 PCM
    Jul 2023
    2
    Hello, I am new to this forum and tuning but I currently have a 2000 Z28 Camaro running the factory LS1 coils and I'm wondering if there is anyway that I can run a set of LS3 or gen 4 D510C coils with my factory computer, I have already attempted this one time with no success. When I installed the LS3 coils the car had a horrible misfire, Any help would be greatly appreciated.
    Mar 2022
    Indiana
    2,951
    Did you try it with Spark>Dwell settings copied over?
    Jul 2023
    2
    Just tried it and everything worked fine except, scanner reads that Ignition coil 6 control circuit failed I'm guessing that means there's something internally wrong with the ignition coil? Please educate me if I'm wrong though
    Mar 2022
    Indiana
    2,951
    That or the wiring. It's probably damaged from the incorrect settings you had.
    Nov 2006
    2,742
    I've never had any issue.. Changing tune isn't required for that. They just bolt on and go.
    Tuner at PCMofnc.com
