Results 1 to 5 of 5
Thread: os for segment swap
    Dec 2019
    Meridian Ms
    113
    os for segment swap
    I am trying to find an OS that will work with my pcm. I swapped a 2005 5.3 and computer into a 99 K3500 and kept the 4l80 and i been threw everything from 2004-2006 in the repository and the only os that was the same was from a 2005 crew cab GMC 2wd which is exactly what the engine and pcm came from. I have not liscensed the pcm yet because i wanted to make sure it would work. I have a ton of these old P59's i could try but this one was with the motor and didn't want to seperate if i didn't have too. the file is below if needed. The OS is 12606961.
    Greggs 99 dulley with LS STOCK DO NOT WRITE!!!!!!!!!.hpt
    Dec 2019
    Meridian Ms
    113
    If noone has an OS i could use can i just copy and paste the 4l80 stuff?
    Thanks, Tody
    405
    2,337
    No you have to have the 4L80 segments or use a custom harness that lets you run an 80 on 60 segments. PCM of North Carolina sells a harness that lets you do that.
    The Pcmofnc harness is very easy to use and works good.
    Dec 2019
    Meridian Ms
    113
    Thanks i was thinking that was gonna be my only option. I never get the easy ones.
    Thanks, Tody
