Results 1 to 4 of 4
Thread: Cam position relearn procedure
    May 2023
    3
    2018 grand cherokee 3.6L that I've had to take apart and apparently they want a relearn procedure after replacing cams, rocker arms, etc. Is this possible within HP Tuners? Where can I find the procedures? TIA.
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    if, then vcm scanner.
    Aug 2006
    5BA8
    3,257
    If it doesn't set a code, don't worry about it. If it sets a code and turns on the CEL, then worry about it.
    EFI specialist
    email=[email protected]
    Jan 2022
    904
    there has to be a way...
    you can do a crank relearn.
    gotta be able to do the cams.
    one at a time most likely but there has to be a procedure
    the guys i would ask are both on challenger talk as well as here i believe
    spoolboy or chally tatum
