Results 1 to 4 of 4
Thread: Ford Racing LU60 Data @ 58psi
    Oct 2009
    321
    I have a 2012 Raptor 6.2 that I am putting a Procharger on, and I am using a set of the Ford Racing 60lb injectors. The Ford data sheet says it is for 39psi fuel pressure, while the 6.2 runs at 58psi. Does anyone have the proper data for this?
    Thanks.
    Mar 2022
    Indiana
    2,951
    Here you go.
    Engine>Fuel>General
    Oct 2009
    321
    So even though the Ford data says 39psi, and the Raptor runs at 58psi, the tune would be the same?
    Mar 2022
    Indiana
    2,951
    Not sure what you mean about the same? That data entered for the injectors is different than stock. The table values in the tune are interpolated from the datasheet.
    The way Ford data works is the injector is rated at 39.15psi then the compensation tables handle different pressure conditions.
    Oh you might mean is the data in the tune the same as the datasheet? What I did is curve fit each table in order to find the values at higher pressures required by your fuel system and tune.
