Results 1 to 9 of 9
Thread: Hot Start Issues After Pulley Tune, 2020 Hellcat
    Apr 2022
    Germany, Stuttgart
    7
    Hello. I recently had my car tuned with 2.85 clutched and 9% lower on pump gas. Plugs 2309 and gapped properly, double fuel pump and FIC 1000 injectors, colder thermostat. The car starts perfect when cold, but if the engine is hot, it takes 2 start cycles to keep running. When pushing the gas pedal a little bit for like 3 seconds on the start up, the engine won?t stall an keeps idling perfectly. No problems when driving under any circumstances and also no codes or MIL. Tune has been changed a couple of times due to the problem. But the behavior hasn?t really changed at all.
    Any help will be appreciated
    Michael
    Aug 2006
    5BA8
    3,257
    Normally I'd say POST A TUNE AND DATA LOG! but this is pretty easy. Too much cranking fuel at warmer temps. That's about as close as I can get to a guess without seeing how boogered up your tune is.
    That being said, 1000cc injectors are pretty big. They have to be dialed in correctly for everything else to function correctly. If they were chances are you wouldn't have this problem. Seriously without seeing a tune file and data log it's all just a guess.
    EFI specialist
    email=[email protected]
    Apr 2022
    Germany, Stuttgart
    7
    Hello and Thank You for the fast reply. I do not have a log yet, but can do one tomorrow. What parameters do have to be logged? Hopefully You can guide me in the right directions. The tune is open, and I also can change parameters by myself.
    I send you the tune via EMail to You
    Best Regards
    Michael
    post file and ill help you out.
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    Try startup inj pw- startup base and set ms on hot a little higher for a test.
    Apr 2022
    Germany, Stuttgart
    7
    How can I post a file here? Haven?t found the button yet🤣
    Aug 2006
    5BA8
    3,257
    Quote Originally Posted by HellcatV View Post
    When you go to make a post, click "go advanced".
    Then click the paper clip button.
    EFI specialist
    Apr 2022
    Germany, Stuttgart
    7
    Perfect, thanks for the help. File is beein attached
    Best Regards from Germany
    Oct 2016
    Poland
    1,744
    Injector data...we tuned a bunch kitties with 2.85(picking over 100hp). Hit me up if you need professional tuning service.
    P.S - I speak German
