Results 1 to 16 of 16
Thread: Please Help Avalanche LS 6.0 TCC
    Jul 2023
    37
    I'm Adam,
    I noticed when I applied the brakes and the gas it would bog down. I added TCC to my list and its staying locked besides when in neutral. what can help this? please look at my Log File see if anything needs to be change.
    05 Avalanche
    truck norris cam
    air intakelof file sent to hp tuners.hpl
    4l60e up grade
    flow master fx
    Mar 2022
    Indiana
    2,939
    Log TCC Slip and TCC Mode.
    Also, you still need to fail the MAF even though the 2bar SD OS is applied. Engine Diag>Airflow>MAF Fail Frequency High to 0Hz, Engine Diag>DTC P0101-P0103 to MIL on First Error.
    For that matter, why are you using the 2bar OS instead of the 1bar? MAP sensor settings are still 1bar, and you didn't mention boost. That VE table looks like a stock one, and pasting it to the 2bar axes will make fuel trims even worse.
    5BA8
    3,253
    Quote Originally Posted by MUSMULE2RIDE View Post
    I'm Adam,
    05 Avalanche
    truck norris cam
    4l60e up grade
    flow master fx
    Can you explain the sentence in bold? Are you talking about power braking?
    The "TCC applied" can't be right. It says "yes" as soon as the vehicle moves.
    email=[email protected]
    SoCal
    1,562
    Why?
    5BA8
    3,253
    ^^^ lol
    Jul 2023
    37
    no, boost and yes for curiosity tried to break torque. as far as Bar I choose 2 bar since i thought it was right. I adjusted Maf Fail high 0hz also mil on 1st error. how do change to Bar 1? thanks for the responses.
    Mar 2022
    Indiana
    2,939
    Flash your factory file back on it then apply the 1bar OS.
    5BA8
    3,253
    Nothing you said pertains to this.
    Jul 2023
    37
    then im not sure how that was posted. although i did adjust it to 480
    Jul 2023
    37
    when i go to my stock file, and i click OS its only giving me BAR 2 and BAR 3 as options no BAR 1 im using P59 from 05 Avalanche Doner motor isfrom 06 GMC denali LQ4 6.0.
    also after i fail Maf freq and logged numerous times what should be done next
    thanks
    Mar 2024
    32
    *sponge mode: engage*
    Tryna to LEARN this Chinese arithmetic
    Jul 2023
    37
    I went to write my as found file back to p59 Ecu and reads different operating system. Should i reinstall donor ecu back in and try that?
    Thanks for any suggestions
    5BA8
    3,253
    Post your "as found" file as well as your most current modified file. I'm betting the reason it doesn't show a 1 bar COS for you (under the OS tab) and it won't let you do a "write cal only" is because you already have the 1 bar COS applied. Post both files then we'll know for sure.
    Jul 2023
    37
    here is my p059 stock read and my current tune file along with scanner deails. thanks for your assistance
    Jul 2023
    37
    here is other as found file from p59
    Jul 2023
    37
    Could I delete the MAF sensor, im a DA but trying to learn from my mistakes. What can can be done to correct bar2 back to Bar1. I do have flex fuel I used fuel rails from my old 5.3, which the 6.0 denali engine did not. Any help is greatly appreciated
