Results 1 to 12 of 12
Thread: Silverado 2005 gen 3 stage 1 tune
    Mar 2024
    NOGALES,MEXICO
    17
    Question Silverado 2005 gen 3 stage 1 tune
    Whats up guys I will drop a tuned file this is my first tune I did a stage 1 but its only a stock tune file I got from the tune repository, stock tune I grabbed was pretty high on some graphs I know I need to adjust spark advance high octane table but other than that what are ur thoughts?
    SILVERADO EQ N IDLE.hpt this is the tuned file.
    11544415958.hpt this is stock file.
    Nov 2017
    1,466
    What does stage 1 mean in this case? What mods are done?
    Mar 2024
    NOGALES,MEXICO
    17
    So basically stage 1 i was thought when a car was stock or has aftermarket air filters (cold air filter/high flow filter), bigger headers or performance exhaust systems i only calibrated: IDLE-BASE SETPOINT ; GENERAL-STOICH AFR I DIVDED THAT BY MY DESIRED EQ RATIO WHICH IS 12.5 AND APPLIED THAT TO MY POWER ENRICHMENT EQ RATIO(GAS) WHICH GAVE ME 1.174 ; LOWERED THE COLD TABLE ON THROTTLE TO A 60 FOR MY TPS; POWER ENRICHMENT DELAY SET ON 5000 RPM, DELAY SET ON 0.0;
    POWER ENRICHMENT RAMP IN SET TO 4.000 ETC. THATS WHY I SHARED THE ORIGINAL FILE SO U CAN OPEN UP AS COMPARE FILE.
    Nov 2017
    1,466
    By mods I meant to the car. Everyone has their own idea of "stages".
    Mar 2024
    NOGALES,MEXICO
    17
    Stock sir i got the file from hp tuners just to practice
    Jan 2015
    Arizona
    448
    Quote Originally Posted by Mikeloko View Post
    I did a stage 1
    you did a what?
    This or that term makes zero sense.
    But, your 'hpt' file is useless for us to see. You need to do a log and post that.
    We really cant tell from your editor file whats going on.
    Now you low octane table has a weird row down low.
    Your VE table looks high for a stock engine.
    Your spark looks safe
    Do a log and post that. Then we can see the timing, if its being retarded do to knock. The fuel trims, if its lean or rich..etc
    Its not an easy thing to pick up. I bet it takes 4 to 6 weeks before you start to get an idea of what does what.
    Nov 2017
    1,466
    Quote Originally Posted by bk2life View Post
    you did a what?
    From what I can tell he isn’t really tuning a vehicle. He made changes to a stock file and wants a grade on how well he changed it for theoretical mods.
    Aug 2006
    5BA8
    3,253
    Jeebus.....
    EFI specialist
    email=[email protected]
    Mar 2024
    NOGALES,MEXICO
    17
    Yes gstorey is right im just tryna be corrected the file i uploaded is a random file i got from tune repisitory to practice on ive never really tuned a car, i just want to know if im in a good path of knowing how to calibrate(tune) tables. im aware that i need logs to know about any knock or so, basicallly just need you guys to grade the calibrations i made or which table im wrong. Tats why i uploaded the stock file and the file i made calibrations on so u guys would see the differences on tables I made calibrations on.
    Aug 2006
    5BA8
    3,253
    Go play in traffic.
    EFI specialist
    Jan 2015
    Arizona
    448
    im in a good path of knowing how to calibrate(tune) tables. .
    yes you are going in the right direction
    Nov 2021
    34
    Log first then tune. Setup histograms in VCM scanner based on tables in your VCM editor then go drive and copy and paste depending on what you are logging. There's a lot more to that, it isn't that simple. I recommend watching Youtube videos to give you a better understanding of what needs to be done.
    Daily driven
    Chevy Tahoe 5.3 bored to 5.7 3.898, flat top pistons
    TSP 212/212 112 LSA CAM, beehive springs, 799 heads
    TBSS intake and throttle body
    4l60e with shift kit and 2800 FTI stall, corvette servo
